Help , Clutch problems
Steve-E30
East Sussex Hooligan
Sat Jun 09, 2007 11:21 am
Have put a new master cylinder and a slave cylinder on the e30 and last night the reservoir where its topped up was nearly empty again :cry:
Im losing fluid and have no idea where , Any ideas guys , I bled the system when i put the slave cylinder on and im lost on what to do :?
Giggety Giggety Goo!!!
Martinaston
Sat Jun 09, 2007 12:31 pm
When you put the new master cylinder on was it an aluminium or a steel one ?
There is NO nucleus.
Steve-E30
Sat Jun 09, 2007 1:44 pm
Cant remeber mate as one of the guys at work fitted it , Have checked for leaks and cant see any , Does the slave sit flush to the gearbox or is there a very small gap , As the old one was caked it crap and when the new one was fitted it sits on the gearbox ok and bolts up fine but the nearside has a small gap , Im talking approx 2mm ??
Steve-E30
Sat Jun 09, 2007 6:59 pm
325icabby
Sat Jun 09, 2007 8:19 pm
i had this once! it was the pipe perished on the master cylinder, the juice was running under the carpet so took ages to find! :x
Steve-E30
Sat Jun 09, 2007 8:28 pm
Checked that mate and nothing , Was one of the first places i checked but cheers for mentioning it :wink:
Got me baffled at the mo as im forever topping it up to save the reservoir running dry :?
dogcoat
Sat Jun 09, 2007 8:35 pm
Have you tried putting the old slave on with the new master. I had a problem where it would not go thru. For some reason this worked. Don't ask why?
Steve-E30
Mon Jun 11, 2007 11:54 pm
Sorted now chaps , Cheers for the replies , Was the fury pipe going to the master , Spoke to ant today about it , Hes one top banana :cool:
