Wiper converstion
shazE30
Thu Jun 07, 2007 11:34 pm
hello all....well over the past year iv owned my cab iv gone for the euro
look deep dish borbets lowered to the max etc etc was thinking of doing a
single wiper converstion........thing is i wanted to know what u people
think of this any specific kit i should go for, are the wipers any good?
any1 had problems,can it do as good of a job as 2 wipers in real bad rain
any advice/feedback will be much appreciated :D
HartgeH27
Fri Jun 08, 2007 10:54 am
I have had problems with my mono wiper, it definitely is not as efficient as a pair of wipers. Then the main rod which drives the mono wiper snapped after 5 years. Need to get a new rod machined but I still like the look of them and as long as you have a good coating of rainex then they are perfectly adequate.
shazE30
Fri Jun 08, 2007 4:23 pm
cheers mate.......what is rainex and where do i get it from
can you post a pic of your mono wiper also what kit should i buy seen the stormone???
HartgeH27
Fri Jun 08, 2007 4:45 pm
Shaz view it in my album signature
shazE30
Fri Jun 08, 2007 4:51 pm
looks sweet dude :D
HartgeH27
Fri Jun 08, 2007 4:59 pm
Rainex little yellow bottle, halfrauds or similar, cannot remember but around 6 squid - apply and the rain just bounces off - little need for wipers except in torrential rain - really good stuff !
UmarK
Fri Jun 08, 2007 7:36 pm
Hi Shaz, ive got a mono wiper conversion on my car, i got it from Storm wipers on ebay. I was impressed by the quality of the kit but it was pain in the arse to fit, we had to modify the linkage so that it gave enough travel with out the mechanism hitting itself. I also had problems the with wiper arm 'jumping' and causing the scuttle to flex. Its OK in the rain but theres an annoying screeching noise when it goes from left to right, which disappears when it goes back to the left. But at least it looks good, although i wouldn't believe the claims it takes an hour to fit.
Umar.
shazE30
Fri Jun 08, 2007 9:26 pm
Thanx Umar for that......i really cant be asked with annoying problems like the one's youv mentioned altho ur rite they do look cool as fuck......cant make my mind up now :mad:
HartgeH27
Sun Jun 10, 2007 9:07 am
My scuttle flexed as well and needed reinforcing, plus the central position required for the mono wipe means you have to move the hole across a tadge.
BadDave
Tue Jun 12, 2007 7:56 pm
shazE30 wrote:cheers mate.......what is rainex and where do i get it from
This is the Storm wiper fitted
Fitted this afternoon
UmarK wrote:I wouldn't believe the claims it takes an hour to fit.
I agree
Estimate it takes about 1 1/2hrs to do.
UmarK
Wed Jun 13, 2007 10:56 pm
HartgeH27 wrote:My scuttle flexed as well and needed reinforcing, plus the central position required for the mono wipe means you have to move the hole across a tadge.
I think thats what i'll have to do as well as im worried about the paint cracking. I didn't have to move the hole when i fitted mine it lined straight up.
BadDave : I had a lot of problems fitting mine for some reason as the mechanism kept fouling on itself, it seems yours went on pretty easy.[/quote]
BadDave
Thu Jun 14, 2007 9:43 am
There shouldn't be any need to adjust the hole where the wiper spindle goes,other than reinforcing if the scuttle flexes
UmarK.
Yeah it all fitted pretty easily
Just a bit fiddly removiny the old mechanism adn trying to get the new one fitted.
Perseverance/stubbornness and determination won in the end though
