Hi guys, does anyone know if the M20 blocks used in the E30 and the E34 are different in terms of where the alloy mounts actually bolt onto the block itself?
I.e would an E30 M20 fit an E34 and visa-virsa.
Any help much appreciated
Different M20 Blocks?
Andy325i
Templ8e30
Pretty sure that the mounting holes are in the same place but I beleive that the dipstick is mounted in the sump on the e34 rather than in the block on e28/e30 models.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Andy325i
Your a top man. Thankyou
Andy325i
COuld the sumps be swapped over and the hole in the block, blocked sucessfully?
