Wrong diff oil? LSD
TouringMatt
Post Fri Apr 29, 2005 7:28 pm
Would it create grumbling noises if i had the wrong grade oil in?
The LSD makes loads of noise under low speed turning and i can feel it stick a bit when moving off :?
Matt
Post Fri Apr 29, 2005 7:51 pm
if it's a slipper with the wrong oil it will grumble!
TouringMatt
Post Fri Apr 29, 2005 7:57 pm
Oh well, its the cheapest ( and at main stealers prices - i use that term loosely!! ) option, oil change it is!
Matt
Post Fri Apr 29, 2005 8:16 pm
best part of 50 nicker for 2 litres of LSD oil hehe. u need 1.9just take them a 2litre coke bottle for them to fill as u can't get it any other way if u didn't know.
TouringMatt
Post Fri Apr 29, 2005 8:20 pm
Holy christ!!!! I knew it was expansive but............... :mad:
Redline oils no better or cheaper?
Thanks for the tip about the bottle, man thats gonna feel pikey! :lol:
Matt
Post Fri Apr 29, 2005 8:27 pm
i know makes your heart skip a beat! better than open diff wrongness
TouringMatt
Post Fri Apr 29, 2005 8:36 pm
I can get 2L of Redline Lola F3000 gear oil ( 75W/90 replacement ) for Ԛ£43 delivered - sound good??
Matt
Post Fri Apr 29, 2005 8:41 pm
i thought it was a dealer only job, but i may be wrong!
M3Compact
Post Fri Apr 29, 2005 8:47 pm
You can use any fully synthetic good quality LSD specific oil, the stealer stuff is fine.
Is your diff only noisy at low speed when turning?
TouringMatt
Post Fri Apr 29, 2005 9:00 pm
It actually feels like its dragging, thats the best description i can find when im driving say 5-10mph, and when moving off i can feel a little jerk, as if something has just freed itself :(
I replaced all the rear brakes as i thought it was that, but its no different!
I've read they are noisy on full lock, but this sounds terminal! almost like a grating, well, like stuck or binding brakes tbh! :(
I have noticed if the car has stood overnight then its fine for about 10 mins, once its warm then i get problems
Matt
M3Compact
Post Fri Apr 29, 2005 9:12 pm
I don't like the sound of that mate.
How long have you had the car? Have you changed the oil? Or has it just developed this by itself?
TouringMatt
Post Fri Apr 29, 2005 9:16 pm
Picked it up about 6 weeks ago and been working on it since, fella before fitted the LSD.........
Oil level is ok, dont think it was changed when it was fitted though, just checked
Sound fecked to you?
Matt
M3Compact
Post Fri Apr 29, 2005 9:23 pm
More optimistic because it's always done it, possibly wrong oil.
I've never heard one with the wrong oil, but I would've guessed at it being more likely to make the noise when cold.
If it is fecked, I think it's more likely to be the 'open part' (crown wheel/pinion) than the LSD unit.
Sorry, can't be more helpful than guessing really. :oops:
TouringMatt
Post Fri Apr 29, 2005 11:49 pm
I will do an oil change and hope for the best :)
Thanks for your help
Matt
Jimbob
Post Sat Apr 30, 2005 12:02 pm
stealers is Ԛ£35.
