e46 csl corner weights
Mox3d
Post Wed May 30, 2007 7:19 pm
Anyone know/ can find out/ point me in the direction of exactly what the baseline is for a factory e46 M3 csl.
It has to be a totally standard car. Any help greatly appreciated guys, thank you.
Jan.
stuartgallafant
Post Wed May 30, 2007 7:24 pm
What do you mean mate?
Mox3d
Post Wed May 30, 2007 7:42 pm
The numbers, for a bog standard e46 M3 csl minus driver (with or without fuel, doesn't really matter so much). What the weight is under each wheel. This is what I could do with knowing.
It's to help me set up a customer car. Failing this my technical German is not really good enough to talk shop with M gmbh about it, and I may have to try but I thought I might chance it that someone here may already have played with one and know the stock weights.
The trouble is the cars stock corner weights weren't measured on the stock suspension (the scales were on loan), hence the question. It is to give us a better idea of where we can go with it etc.
Cheers.
stuartgallafant
Post Wed May 30, 2007 7:45 pm
make a call to CA Automotive and ask a guy called Jayson, I believe he should know. Failing that, contact your local BMW dealers, they should be able to supply the info
I dont believe there is nothing on the web about this though
Mox3d
Post Wed May 30, 2007 7:58 pm
Appreciated bro, thank you. I'll give them a holler tommorrow as I think we are slightly past CA's 7pm deadline.
Nothing that I could readily find online and I pretty much work online. That came as less of a suprize :wink:
Theo
Post Wed May 30, 2007 8:16 pm
E46 M3 CSL kerb weight is, apparently, 1385 kg (3053 lbs)
Davenotouring
Post Wed May 30, 2007 8:23 pm
Heavy shed, no wonder it's slow. :mad:
There are a few CSLs over at Northloop.co.uk I don't suppose this is for Steve Gills car is it?
Weapon-mobile that car! :cool:
BMW 328i Cab - Daily Slag
Mox3d
Post Wed May 30, 2007 8:36 pm
Theo325 wrote:E46 M3 CSL kerb weight is, apparently, 1385 kg (3053 lbs)
This one was at 1450 with some gas and some doo dads.
Davenotouring wrote:Heavy shed, no wonder it's slow. :mad:
No sir.
