Elec. cab roof motor went bang!
bangerack
Sun May 27, 2007 5:25 pm
Hi, I got home after the southwest meet last Sunday and as I put the roof back up it went clonk and bang. The arm has been ripped out of the casting by the look of it. So any Ideas ???
E30Mark
Sun May 27, 2007 5:35 pm
There is a motor on ebay at the moment!
PM for details
bangerack
Sun May 27, 2007 6:03 pm
Had a nose at that, I will keep an eye on it.
DaveD
E30Zone Wiki Specialist
Sun May 27, 2007 6:27 pm
bangerack
Sun May 27, 2007 7:01 pm
Will do, Cheers Dave
ian332isport
Sun May 27, 2007 7:22 pm
This is worth a look as well 8)
http://www.e30ic.com/powertop.htm
bangerack
Sun May 27, 2007 7:36 pm
Thanks Ian, the first pic on the link looks all to familiarImage
bangerack
Sun May 27, 2007 7:39 pm
ring jason on 07871662902
Oh forgot to ask in my pm, did you get an uprated/improved motor on yours ?, this does seem to be the common failure with elec cab roofs
jabber
Sun May 27, 2007 7:52 pm
had the same problem with mine sent it to jason ( or he can send it to you to do yourself ) to have his modified casing fitted well worth it in my opinion
DaveD
Sun May 27, 2007 9:54 pm
you don't get an uprated motor the new casing is a steel casting rather than suspect alloy
bangerack
Mon May 28, 2007 8:50 am
Brilliant, thats got to be the way forward then.
chu346
Mon May 28, 2007 7:27 pm
DaveD wrote:ring jason on 07871662902
I got no answer :(
DaveD
Mon May 28, 2007 10:57 pm
try on tuesday...or try his bro bill 0768852395...remember it has been a holiday today
gazza
Tue May 29, 2007 10:41 am
i had the same thing on mine i bought the metal repair plate off german ebay bolts over the motor in the hood compartment using the original bolt holes works great now ....and you dont have to take any of the motors out to do it
bangerack
Tue May 29, 2007 1:44 pm
sounds interesting. what happened with the roof set up strategy ?
gazza
Tue May 29, 2007 9:20 pm
nothing as nothing had to be removed or altered bolted the plate on as it is made of steel and replaces the bit of the motorcase that breaks off everything worked again as it should
jabber
Tue May 29, 2007 10:37 pm
can you post a pic of what the plate looks like fitted
gazza
Tue May 29, 2007 10:55 pm
here is the ebay link and its cheaper than the one i bought ....different name maybe cos he can undercut the original bloke by copying it
http://cgi.ebay.de/BMW-E30-Cabrio-Repar ... dZViewItem
or there is this
http://cgi.ebay.de/BMW-E30-Cabrio-Verde ... dZViewItem
link now working
DaveD
Tue May 29, 2007 11:19 pm
the top link is not working and with the other you have to take the motor out cut away the aperture and drill a load of holes and then put it all back together again...and it is still not as good as a steel top!
gazza
Wed May 30, 2007 10:21 am
link above is now working
DaveD
Wed May 30, 2007 11:30 am
looks a simple idea..and its cheap!
jabber
Wed May 30, 2007 11:53 am
certainly does look simple ...do not know how much jasons case is just to buy to fit for yourself but i sent my motor to him and he did it for me for £90 including postage back .
bangerack
Wed May 30, 2007 3:42 pm
But whats the issue of the set up strategy with the roof again?
Martinaston
Wed May 30, 2007 4:21 pm
The levers only slot into the gearbox one way so you just screw it back together with the back window folded for access and then get someone to slowly lower the window so it turns the gearbox so you can re-engage the motor.
The switches are located on the gearbox so the ECU knows where the roof is and should just work as normal.
There is NO nucleus.
bangerack
Wed May 30, 2007 5:33 pm
oh right so its a simple enough diy job then
DaveD
Wed May 30, 2007 7:19 pm
i am not so sure ...i would have a go but I have seen someone do it .There are instructions in the manual in the links section. :?
bangerack
Thu May 31, 2007 10:42 am
I am booked into see Jason and Bill on Saturday a 300 mile round trip,(any excuse to take it out for a spin :roll: ) so I will let you all know.
DaveD
Thu May 31, 2007 10:48 am
have a good look round your car and see if you need anything else as they seem to have loads of parts lying around
bangerack
Thu May 31, 2007 1:14 pm
okay, good call
raulandthetwins
Sun Jul 08, 2007 6:54 pm
This has now happened to my roof what's the best route to go down, there appears to be nothing but praise for jason, is he the man for the job?
Any help please
Raul :cry:
DaveD
Sun Jul 08, 2007 10:21 pm
raulandthetwins wrote:This has now happened to my roof what's the best route to go down, there appears to be nothing but praise for jason, is he the man for the job?
Any help please
Raul :cry:
yes
bangerack
Mon Jul 09, 2007 5:53 pm
Any help please
Raul
Hi Raul
It will cost you around 150 to 180 to have this replaced, set up and "yowd be on ya way" the guys take about 2 hours to do it. My advice is ring Jason or his bro Bill.
Oh and dont forget to take some of your local brew!!!
I had to take some fine Zider, being frum Zummerset
Whilst I was there another fella was up from London town having his motor replaced too.
Go for it !!
raulandthetwins
Tue Jul 10, 2007 10:25 pm
Thanks alot not as bad as i had feared cheers for help guys :D
Mac3
Wed Jul 11, 2007 10:35 am
Hi All,
Recently the same happened to my elec roof, where is Jason based?
Mac
DaveD
Wed Jul 11, 2007 10:47 am
darlaston..junction 9 off m6
07968 852395 bill
07871 662902 jason
