Ok
If I had an early 2.5 engine from an '86 car and had the following parts, which pistons would I need ?
324TD Crank & rods
I don't really want to get into machining the block & head etc.
If I can't use standard BMW parts, what would I need ?
Please don't fill the post with if's & buts.
Hoping to do this soon, so will do a fully documented build with photo's etc.
What pistons for 2.7 ?
Ant
- Retired Team Member
Cant use the TD rods without some major mods to the gudgeon pin area, they are simply massive when compared to the M20 B20/25 units
Crank goes in ok, needs M50 bearing shells, not ETA !
you'll have to machine the block dude, no getting away from it unless you use the Alpina pistons ( @ 120 each + rings) with the B25 135mm rods.
Email FTW
ed325i
Use your early 325 pistons.
If you dont want to get in to machining the block/ head go 2.8
12345kevin
Thanks Ant
It's going to have all new shells, bearing and rings anyway.
So, if I use 324TD Crank, Alpina Pistons, M50 Shells, standard 325 rods, block & head. This will create a 2.7 without any machining ?
Part no. for the alpina pistons ?
- **BANNED**
Where did you find the crank?
Andyboy
- Alpina Colada
Or use standard 325i pistons for a lot less money and spend £30 decking the block. Alternative number 2 is to use 525e pistons. They work fine with the 325i head and still give a decent compression ratio.12345kevin wrote:Thanks Ant
325i rods won't work with 325i or Eta pistons as they are too long so use 320i/323i/Eta rods.
Your early pistons will need 10mm taking off the bottom skirt to clear the crank webs.
