would seats from a 91 7 series fit a prefacelift e30?
I doubt the rear bench would fit but would the fronts fit ok?
7 series seats in e30?
choppa7
1990 318i Lux
gareth
you'd be lucky. they're hoooooooooooooooooooooooge!!!
they'll go in a E34 though.
you'd be better off putting them in your living room!
snoops
- Major Helmet
Yaninnya
I have E30 and E34 and I was making some measures. They are not so huge as Gareth described but the biggest problem can be heigh of sitting position (it is similar to E30 comfort seat which is to high for me). If you are traveling a lot it is worth to consider, the E34 (and E32 - they are the same) seats are a loooot more comfortable. You need to make whole new subframe mountings, they are completely different.choppa7 wrote:would seats from a 91 7 series fit a prefacelift e30?
And you are right about rear bench. I even wasn't measure it. No way.
I hope this help a little.
Jan
cliffybabe
- Powered by Nelly
i fitted e36 seats in the front of my cab and there well high
