Accelerator Pedal removal.
Thu May 24, 2007 6:25 pm
How does the throttle pedal come out of the floor? Want to tackle a carpet change but dont want to break the hinged part of the pedal. Can't see any bolts through the floor from underneath either.
When I took the new carpet out of the donor car i jus snapped the pedal off at floor level. Don't want to do that now though.
wildeian
Thu May 24, 2007 7:27 pm
IIRC it just clips to the body under the carpet (through the hole)
I'll check the loose pedal I have floating around in the garage.......
Thu May 24, 2007 11:36 pm
It's not actually intended to be removable without breaking it, but will usually pull out if rocked from side to side.
Thu May 24, 2007 11:41 pm
Got it out okay. As you say rock it from side to side and it does break free.
wildeian
:roll: Ooops!
KDS
Fri May 25, 2007 3:49 am
So, it sounds like there is SOME risk in attempting to remove it, even if you use the right technique. And if it does break, are you completely screwed?
-KDS in Vancouver ('88 325i Touring)
Fri May 25, 2007 8:40 am
KDS wrote: And if it does break, are you completely screwed?
No; you simply ask your dealer for a new one.
Car is still completely drivable without it. I've done it many times when the carpet has been out for some reason or other.
