DIFF
orr
Does anyone know if the z m coupe diff will fit the e30 i know people put the diff cover on with the bigger cooling fins but will the whole diff fit
oze30
in a word.. yes!
The whole diff will fit. Go for it as it's a nice ratio if you've got an engine conversion.
Turbo-Brown
- Boost Junkie
And if you've still got the trailing arms left over, tell me how much you want for them
kam-325i
Is the rear end of the Z3 based on the E30 ?
Turbo-Brown
- Boost Junkie
I believe the whole rear subframe will swap over giving you 5 stud rears, a diff and bigger brakes too.
orr
Are the input shafts the same as an e30 m3 becouse they are missing on the z m coupe diff
