AFM: Those who Know please check this out!!
Jay07
Thu May 17, 2007 6:18 pm
Hey People!
In my long running saga for keep a steady idle im now switching the AFM!
I bought one from Spadge and have just changed it!
Please can you guys confirm:
1. Does it matter that the last digit of the part number is different?
original: 0 280 202 083
replacement: 0 280 202 082
will this effect the performance of the meter?
2. If the above is not an issue, should the ecu need time to adjust because the engine with the replacement one in, sounds like its having a asthma/heart attack??
Cheers guys
Jason
Chris-W
Thu May 17, 2007 6:35 pm
082 is a 325i AFM - I'll just check what the 083 is. Is yours a 320 Jay? Can't remember....
Jay07
Thu May 17, 2007 7:07 pm
Hey Chris! mines a 3.20i - Cheers J
Dr Firefly
E30 Zone Doctor
E30 Zone Doctor
Thu May 17, 2007 7:36 pm
If it makes you feel better Jay my 320i's running on a 325i one without any problems...
tylerma wrote: you oxymoron, you...
Jay07
Thu May 17, 2007 7:58 pm
Cheers FireFly that helps but i would still like to confirm via the part No. just for peace of mind that it would/wouldnt be a problem - I changed it back for now the engine was struggling with the replacement 1 BIg time, the car was shaking as the engine struggled to breath... well that the best way i can describe it... kinda like the sound of blowing/flapping your lips to make a fed up/horse sound....every other second... ppppppp.......pppppppp.......pppppppp ...... I dunno, this issue is doing my head in!!! I just want a steady happy idle......I changed the FPR whilst i was there too to see if that makes a difference!!
SPADGE
Fri May 18, 2007 6:30 pm
Jay that AFM came straight off a 320 and that ran perfectly :?
No idea what going on there!
wullie325i
CAUTION - unreliable trader!
Sat May 19, 2007 3:33 am
hi
sounds like you may have a leak in one of your hoses?
just a thought
wullie
k
Sat May 19, 2007 8:46 am
After changing the AFM would have thought you need to have the CO rechecked, and adjust the AFM as necessary.
Jay07
Tue May 22, 2007 9:38 am
Hmm :? Nothing is ever simple! Ok so assuming its a working unit i dont understand why the difference is so great? Does that hint to anything?
But would there be such a difference? I need to find a realiable mechanic to check this
Is there any particular hose that comes to mind chaps?? ive check most of those around/going to the throttle body! and theres no obvious leaks?
On the metal body of the AFm there is a screw at the bottom of a hole/resess that you can turn, what does that do exactly? Its an adjuster of some type??
rj
Tue May 22, 2007 10:52 am
The hex key adjuster, at the bottom of the recess adjusts the idle mixture. Don't turn it unless you have access to an exhaust gas analyser. It effects the CO % level.
Any local garage, who do MOT's, will have one and can set it in a matter of minutes. Go to where you have your MOT completed and hopefully they will do it free of charge.
k
The AFM adjustment screw is normally set at factory, sealed with the tamperproof plug etc....and the CO will be 1.0% plus or minus 1/2%.
However during the life of these old girls the well meaning owner/twiddlers can have adjusted this allen screw to cure another fault without realising what the consequences are. The Haynes manual gives you all the info on how to set it in conjunction with the CO meter in the servicing section at front, and know that from my own experience that if your outside the spec. the car can be a bit rough on idle and jerky at low speed/ town mode, which seems to be a favourite problem on the Zone, and is a subject all on its own, however these great engines should be smooth and run without glitches, otherwise BMW wouldn't have sold so many.
Not saying that this will sort it in your case, but since you have changed the AFM its just something to be aware of.
karldan
Tue May 22, 2007 6:34 pm
whats the difference between a 320 afm and a 325 afm
kam-325i
Tue May 22, 2007 7:49 pm
Heres a tip for AFMs........
We all know that all AFMs are calibrated at the factory......each one is slighty different........electrically.
Have a look by the screw that is used to adjust the air by-pass for the idle C02. On the casing, near the hole, you will see 3 numbers. These 3 numbers are a measurment, in mm, ie : 14.6. This measurement relates to how far down the screw must be for that AFM to be set correctly.
cliffybabe
Powered by Nelly
Powered by Nelly
Wed May 23, 2007 12:59 am
Jay any funny noises coming formt he car like a weak air leak, manifold gasket maybe???
