Tips on keeping arch's rust free....
dimebag_from_hell
Post Sun May 20, 2007 6:37 pm
Anyone got any tips on keeping your arch's spotless?
fuzzy
He who sleeps with "Gingers"
Post Sun May 20, 2007 6:41 pm
apart from sealing your car in a sealed bubble and never using it theres not much you can do but wait for the rust to appear. and it will :cry:
Kedge
Post Sun May 20, 2007 6:42 pm
Just make sure you clean them proparly everytime you wash the car. If theres no rust in there at the moment maybe worth getting some underseal in there.
Instagram - Kedge85
domross
Post Sun May 20, 2007 6:46 pm
if they have rusted and been repaired then chances are the rust will reappear what ever you do....other than that if they haven't rusted , a rust resistant stone chip protector (waxoyl/dinatrol both do them) and clean, clean and clean again the lips under the arches are a good trap for mud ...make sure you keep these mud free and the rust will be v.v. slow to appear (if it does at all)
d6dph
Post Sun May 20, 2007 6:58 pm
C76jon recommended that I smear a thin layer of petroleum jelly (vasaline) along the inner lip to stop mudclinging there.
A regular clean and dress will keep them fresh.
dimebag_from_hell
There is no rust at all! Looks like waxoyl is the way to go for the arch's. Any tips on how to apply this stuff to your arch's?
dimebag_from_hell
Post Sun May 20, 2007 7:00 pm
http://cgi.ebay.co.uk/Classic-Vehicle-H ... dZViewItem
This looks like good stuff......pretty cheap too!
domross
Post Sun May 20, 2007 8:21 pm
wheel off ,and either high pressure hose to clean...or wire brush for inner arch and then paint brush....make sure as clean as possible and as dry as can be before you apply underseal....
maxfield
Post Sun May 20, 2007 8:22 pm
d6dph wrote:C76jon recommended that I smear a thin layer of petroleum jelly (vasaline) along the inner lip to stop mudclinging there.
What i would do.
dimebag_from_hell
Post Sun May 20, 2007 8:29 pm
Think ill get the wire brush out :twisted:
beardymat
Post Sun May 20, 2007 8:33 pm
keep them cleaned out well and apply some fresh underseal to the underside and waxoil from the inside.
on my resto project it was the inner arches that had got the worst problems and they didnt have much waxoil on them inside.there were some places on mine where no amount of re undersealing and waxoiling would have stopped the rust but if yours are good now then you probably dont have these problem areas.
dont forget to drop the plastic guard down that protects the filler neck and clean behind there as its a proper mud trap :(
d6dph
Post Sun May 20, 2007 8:38 pm
I really wouldn't do that IMO.
If they are not rusty now, why do you need to use something that harsh?
I done some arches on a mates mk6 escort that I detailed for him a few weeks ago.
Used megs APC and a stiff brush to get the muck off and then dressed the plastics with chemical guys new look trim gel.
Before:
After:
Full write up can be found here:
http://www.detailingworld.co.uk/forum/s ... hp?t=31572
dimebag_from_hell
Post Sun May 20, 2007 9:05 pm
d6dph wrote:I really wouldn't do that IMO.
Before:
After:
It just seems waxoil underseal will protect much better than anything else. The roads i drive my sport on are so mucky, my arch's are regulary covered in cow crap, mud and god knows what else. I definatley need to protect the arch's.....
maxfield
Post Sun May 20, 2007 9:07 pm
Awesome dave!
dimebag_from_hell
Post Mon May 21, 2007 3:52 pm
beardymat, you got a PM! :D
dimebag_from_hell
Post Mon May 21, 2007 5:33 pm
Is this a good underseal to use for the arch's? Also anyone got any tips on undersealing the bottom of the car, think i might aswell go for it if im doing the arch's...
beardymat
Post Mon May 21, 2007 6:21 pm
dimebag_from_hell wrote:beardymat, you got a PM! :D
not come through buddy
dimebag_from_hell
Post Mon May 21, 2007 6:40 pm
is your pm box full?
beardymat
Post Mon May 21, 2007 7:32 pm
only 40% full at the mo
had a few probs with sending and receiving lately,try sending again :roll:
aceraf
Post Wed May 23, 2007 5:27 pm
What do all you people with lowered cars do in terms of cleaning the inner arches?
My last car was lowered, and i couldn't get my hand in the arch to clean (and jacking it seemed OTT)...
I used to use my pressure washer on my car before lowering, but once lowered, it took only a few months for the mud in the arches to cause rust to come through....
with the intention of slamming this, or my next e30, will i end up with the same issue???
Breaking 325i Touring
tezk
Post Wed May 23, 2007 5:44 pm
Just ordered a tin of that underseal! I've got a tin of spray I use on any scratches I spot underneath but didn't fancy spraying the arches.
hubble
Post Thu May 24, 2007 9:15 pm
aceraf wrote:What do all you people with lowered cars do in terms of cleaning the inner arches?
I know it may take some time to do this but it's worth it. If you value your E30 irrespective if it's been lowered or not you need get each wheel off and give the arches a proper clean. I use TFR diluted left for a short time and then pressure washed off.
Then using a hard bristled paint brush they are cleaned again with soapy water, rinsing in between.
Frenchy
Post Fri May 25, 2007 8:49 pm
MUD ! Get rid as it is a moisture trap clean underneath the arches touch up any damaged underseal and clatter the waxoil on afterwards but most of all keep the mud washed off .
A mate has a"52" e46 33Oi wheel arches just repaired the wheel arches could have grown tatties full of mud=rust. 8O
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......;-)
snoops
Major Helmet
Post Sat May 26, 2007 4:53 pm
:cool: :cool:
