Oil leak
325SME
Post Wed Apr 27, 2005 7:30 pm
I think, after many months, I have found the source of my oil leak. It appears to be coming from the mechanism (listed as the oil filter head on the online ETK) the oil filter and oil cooler pipes go into that's mounted on the drivers side of the engine. Looking from below there's a cylindrical shaped piece that seems to have a circlip of some description inside it and some form of cross marking and this is where the leak is coming from. No pics as yet to help identification but if this rings any bells is it easy to sort out?
Steve
Post Wed Apr 27, 2005 7:32 pm
speaking to a bmw techy on monday this is very common! mine has a slight one there too. dunno if it's a hard job!
bosshogg
Post Wed Apr 27, 2005 9:26 pm
Mines the same and I,ve been told you can buy the internals from the stealers and they're not that much but haven't got round to it yet
billgatese30
Post Wed Apr 27, 2005 10:00 pm
mines hte same.....leaked about two drips when i first got the car....never had any problems since, but it was mentioned when the car was serviced on friday, said coming form the distributor area.
Post Wed Apr 27, 2005 11:05 pm
There is an O ring behind the cap under the circlip, which will have become hard and brittle with age and heat.
The new O ring comes as part of a kit for less than Ԛ£5 IIRC, and includes the cap and circlip.
Very common oil leak (amongst the dozens of other very common oil leaks on the M20), and easy to fix. Watch out for a part behind the cap that may fall out when you remove the cap.
325SME
Post Thu Apr 28, 2005 7:52 pm
Brianmoooore wrote:There is an O ring behind the cap under the circlip, which will have become hard and brittle with age and heat.
Cheers Brian, once again you've come to the rescue! Time to phone the stealers methinks...................
PS How simple a job is this? Does it involve draining the oil at all?
Post Thu Apr 28, 2005 10:54 pm
Simple job. No need to drain oil. Only tools needed are circlip pliers and a smallish screwdriver for levering etc.
325SME
Post Fri Apr 29, 2005 7:17 pm
Lovely jubbly, thats the kind of job I like!!!
