turbo or supercharger???
Doddy
Post Thu May 17, 2007 6:15 pm
im going to be suping up the touring at some point this year, just wondered which is the best way of doing it on a 2.5.
i built a cavalier turbo last year so not shy on some hard graft
any help/opinions appreciated
buster
Post Thu May 17, 2007 7:08 pm
turbo
Turbo-Brown
Boost Junkie
Post Thu May 17, 2007 7:11 pm
Turbo(s) :D
buster
Turbo-Brown wrote:Turbo(s) :D
8)
Jon_Bmw
Dangerous when thinking
Post Thu May 17, 2007 7:13 pm
Doddy how did you do that, did you use c20let turbo/manifold/inlet on a c20xe or god forbid a x20xev?
Isn't the compression slightly higher on those engines?
Turbo definatly. Try and source a BBR manifold, these are a very nice log type manifold that has good access to spark plugs.
e30_Turbo
Boost Junkie
Post Fri May 18, 2007 11:15 am
Turbo all the way!!
But then again I am biased :cool:
HTH, Mark.
Doddy
Post Sat May 19, 2007 11:54 am
Jon_Bmw wrote:Doddy how did you do that, did you use c20let turbo/manifold/inlet on a c20xe or god forbid a x20xev?
i dropped a c20let engine(the whole lot) in it with a hks intercooler uprated oil cooler etc
was good for 350bhp
Doddy
Post Sat May 19, 2007 11:55 am
im guessing turbo is the way sounds good to me cheers
midnight
Post Sun May 20, 2007 7:23 pm
yeah i would also have to say turbo, the m20 engine responds very well to slapping a turbo on it without having to spend big money on engine internals, obviously there is going to be a bit of graft involved if you are doing it your self, but most parts for the conversion are quite available, you just have to know wehere to look and what to use parts from, ive ended using a lot of ford parts and a few cosworth bits to get mine moving.
fuzzy
He who sleeps with "Gingers"
Post Sun May 20, 2007 7:32 pm
isnt turbo'd easier for power upgrades in future? and do you get the loud dump valve hiss from supercharged.thats got to swing it on its own but im also biased :D
maxfield
Post Sun May 20, 2007 7:39 pm
Both.
Yaninnya
Post Sun May 20, 2007 8:48 pm
+1 winkeye
Jan
dips346
London Meets Main Man
Post Sun May 20, 2007 9:39 pm
maxfield wrote:Both.
oze30
Post Sun May 20, 2007 10:06 pm
Compund it.. It'll be the dogs danglies and most ppl will eat your rubber!!!
gareth
Post Sun May 20, 2007 11:21 pm
jag blower :cool:
bottlecapE30
Post Sun May 27, 2007 4:49 am
i say it depends on what you want form the car.
Turbo will give you the highest gains, but can be a little tuffer to tune
Supercharger on the other hand will give you more linier power (easier to tune and gives more low end power) but harder to get big power.
Of corse you also have to think about what type of supercharger you are looking to use. Roots chargers are very different in the way they give there power then say a centrifugical (sp?) charger. and that is totaly different then a twin screw. You really should sit down deside what you want as far as power and were you want that power. also consiter that you may want to go bigger in the future. With a turbo you can fiddle with boost controlers and with a supercharger you can change the pulley size.
I like superchargers thou, granted there is more suport for the turbos.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
gareth
Post Sun May 27, 2007 8:17 am
i simply HATE turbo lag!!! that's the reason i loke superchargers so much. oh, the howl is cool too!!!! :cool:
FlappySocks
Post Sun May 27, 2007 1:50 pm
Supercharge would be my preferred option for a road car.
