swapping spoilers
march109
Post Wed May 16, 2007 1:50 pm
How easy (and how) is it to swap a tech2 spoiler onto a new boot lid.
I have a new boot in the right colour and doesn't need spraying but its an IS so want to put the spoiler from the sport onto it. How is it bonded? and how is it refitted?
Ziggy
Post Wed May 16, 2007 2:03 pm
Nuts 'n bolts mate... you can see em from inside the boot :thumb:
march109
Post Wed May 16, 2007 2:08 pm
yeah got that far but the tech2 is still not coming off! I think its bonded with something.
Ziggy
Post Wed May 16, 2007 2:10 pm
Shouldn't be... Are you sure you've got all the nuts off? Might just be the threads catching on the holes? Or perhaps one of the studs has broken off at some point & someone's bodged it with some no-more-nails? :?
Think tech-2 spoilers have a couple of extra brackets (on the sides), but they should be obvious...
march109
Post Wed May 16, 2007 2:18 pm
Pretty sure I'll take another look after work, but its doing my head in! Other than some idiot glueing it down (which I thought wasn't possible!) I don't really know why it won't budge!
:x
Ziggy
Post Wed May 16, 2007 2:20 pm
How hard have you tried to budge it? They usually take a couple of taps (say on one of the studs with a li'l socket extension bar or something) to loosen the studs from the holes...
march109
Post Wed May 16, 2007 2:28 pm
:lol:
I'm not very good with variable manual pressure applicators, I'm too heavy handed! but I'll try with something soft first!
Ziggy
Post Wed May 16, 2007 2:31 pm
Percussive maintenance is always the answer! :D
Jon_Bmw
Dangerous when thinking
Post Wed May 16, 2007 2:41 pm
I have a sledge hammer you can borrow?
march109
Post Wed May 16, 2007 2:48 pm
I'll smash it to bits with anything bigger than the end of a big screwdriver!
aceraf
Post Wed May 16, 2007 5:10 pm
I have a tech 2 spoiler...and found that it has 4 mounting bolts, where as the standard one only has 2 on mine...(i think it's that, or 4 and 6)....so you may find you need to drill extra holes, or cut 2 of the bolts off....
mine is a fibre-glass replica though, so an original may be different....
Breaking 325i Touring
