OIL FOR SPORT LSD....
dimebag_from_hell
Tue May 15, 2007 12:07 pm
How much oil do i need for the lsd on my sport, i am ordering oil in for a service......so need advice a.s.a.p
cheers guys
dimebag_from_hell
Tue May 15, 2007 12:25 pm
Is it really necessary to change the gearbox oil? If so how much will i need for it and the LSD
march109
Tue May 15, 2007 12:30 pm
before you can order it you need to know the colour of the tag which determines the grade of oil ou require, as for capacity I'm not sure it should be in Haynes but I cant find it!
Its probabl a job you could do yourself if you wanted, but I don't think its an annual type service item.
JonnyBravo
Tue May 15, 2007 1:09 pm
dimebag_from_hell wrote:How much oil do i need for the lsd on my sport, i am ordering oil in for a service......so need advice a.s.a.p
cheers guys
1.8l i think mate, i get mine from Lagan Motor Factors in Lisburn (02892607378), Castrol SAF-XJ never had any problems with it apart from the smell of it lol
Jonathan
dimebag_from_hell
Tue May 15, 2007 2:21 pm
Yep ive been told Castrol SAF-XJ is perfect for 99% of diffs so thats what im going for. Hows the 2.7 running jonny? You get your liscence back?
What about gear box oil, i got a short shifter from a z3 in her, is it worth changing the oil?
chicken
Tue May 15, 2007 2:38 pm
best bet is to call up your local bmw dealer
i called mine telling them i was gonna buy some they are more than happy to help then popped down halfrauds and it was a tenner cheaper winkeye
Templ8e30
Tue May 15, 2007 5:54 pm
Gearbox (manual) will be 1.2 litres of SAE 80w gear oil.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
dimebag_from_hell
Tue May 15, 2007 6:38 pm
How often should gear oil be changed, is it really necessary?
cheers
JonnyBravo
Wed May 16, 2007 10:38 am
Yes mate got the license back :D but no car at the mo lol sent her away to get a wee tidy up (mainly the rear arches)
Check what gear bag you have mate, should be one of the getrag ones and see what grade you need. I've only replaced mine the once and the only reason I did was... it was out of the car at the time
Jonathan
Templ8e30
Wed May 16, 2007 1:01 pm
It's like any other oil, it breaks down over time and needs changing.
Gearbox and diff oil only needs to be changed at an inspection 2 service (every other major service) so every couple of years.
Cheers,
Iain T
dimebag_from_hell
Fri May 18, 2007 1:34 pm
Yes mate got the license back but no car at the mo lol sent her away to get a wee tidy up (mainly the rear arches)
Mines of the road at the moment too, getting lights sorted for MOT. I'll have her fully serviced and MOT'd in the next 2 weeks, hope to see your sport up around the north coast in the summer :cool:
