jmc330i wrote:That's for the M50? Just out of interest, what flywheel and clutch combo is that using?Anybody wrote:the only readily available gearbox is the E30 318i M40 box
I read on here somewhere that the M50 clutch and flywheel can be used with the M40 box, but wasnt sure if that's right or if you get the same problem of the gearbox rotating like with the M20 box.
It may all fit together but like anything else its only an idea until someone has actually done the conversion and run it IMO.
Personally I wouldnt use a 318 box on the back of a 200hp engine
