wiring woes
JohnnyThunders
Sat May 12, 2007 4:40 pm
First ever attempt at wiring a stereo, thought "piece of piss" and then realized i have no idea which wire goes where... anyone help me out maybe? some edited paintshop arrows would be nice, but any help is appreciated.
cheers in advance.
JT
carlos_320i
Sat May 12, 2007 4:42 pm
What h/u is it mate
And do you have a multi meter??
JohnnyThunders
Sat May 12, 2007 4:44 pm
carlos_320i wrote:What h/u is it mate
Its a crappy old Pioneer KEH-4090 and no i do not have a multi meter. :?
carlos_320i
Sat May 12, 2007 4:55 pm
Do you know what is live on the h/u
On the car if I remember rightly red is battery live black is ground and I cant remember what is ignition live
Sorry mate :o:
JohnnyThunders
Sat May 12, 2007 5:38 pm
Ok the car has one red/green wire, when i connect this to the red on the stereo and plug the main big black proper plug thingie in, i can get the tape surround to light up when i turn the stereo on. I also attatched the brown wire on the car to the black wire on the head unit, nothing seems to change, i am then presuming the blue is ignition live, but on the car there are 2 blue wires and on the head unit it is only 1. The rest of the wires are speakers then? if i can get the earth live ignition right i guess the rest will work itself out, as i cant start a fire with speaker wires right? :?
carlos_320i
Sat May 12, 2007 6:24 pm
Mate you need to get a test meter its going to be the easiest way
Where are you based :?
jcjdavis1
Sat May 12, 2007 7:59 pm
Hi look in Styling/Ice,go to page 2 and look for "wiring stereo in".You will get some help there.I got the wiring loom you see and it worked a treat.hth Jim
Sat May 12, 2007 11:05 pm
carlos_320i wrote:Mate you need to get a test meter its going to be the easiest way
You do not need a test meter! Meters give totally misleading results on unloaded circuits, and in the hands of persons who are not familiar with them. Just use a 12 volt 5W lamp on a couple of pieces of wire.
A front indicator repeater from a scrap E30 is ideal.
jcjdavis1
Sun May 13, 2007 8:13 am
Hi Left a reply on stylig/ice
