oil leak
FLEX
Fri May 11, 2007 4:37 pm
:( right then ive got a oil keaking some where but i cant see it on my drive but you can smell it and near the front under the distrurbiter i can see oil i just want to know are there any common problems where they leak from by the way its a 325i thanks :( :(
Gwynne26
Fri May 11, 2007 5:50 pm
Head gasket leaking, or camshaft oil seal?
koos
Fri May 11, 2007 5:51 pm
Mine leaks there too, try the camshaft seal at the front or the tappet cover gasket. If not, then its the head gasket, thats were mine is coming from, I here its quite common.
Mitch
FLEX
Fri May 11, 2007 6:32 pm
the car had a head gasket done about a year ago is it quite easy to change cam-saft seal
