m30 or m50
munky30
100% Pure Council
Wed May 09, 2007 4:32 pm
ahh ok, thought you meant the shiny tubey things that go for £400+ :roll:
Does the same mod need to be done for an M52 conversion?
Rosc0PColtrane
Wed May 09, 2007 4:38 pm
Sounds far more cost effective!!!
munky30
100% Pure Council
Wed May 09, 2007 4:40 pm
Please ignore this comment! They're basically the same engine so of course the mod needs to be done....
:o: :roll:
eko
Old timer
Wed May 09, 2007 4:41 pm
munky30 wrote:ahh ok, thought you meant the shiny tubey things that go for £400+ :roll:
Yes i assume so!
Heres my original engine conversion thread,loads of pics in there :D
(Wiow brings back memorys)!
http://www.e30zone.net/modules.php?name ... ic&t=43766
dazleeds
old skool raver
old skool raver
Yes i assume so!
eko no link :wink:
www.oldskoolfantasy.co.uk
munky30
100% Pure Council
Wed May 09, 2007 4:42 pm
yes there is :?
Rosc0PColtrane
Wed May 09, 2007 4:43 pm
Can someone cut the pics into this thread for me please?
Jimbob
It's a case of see what happens to be honest mate. I've got a 328i front section cut down, ready to be welded to my aftermarket system (same pipe diameter). The M50 and M52 share the same problem of the exhaust manifold hitting the steering UJ - so this also needs cutting and welding.
eko
Old timer
Wed May 09, 2007 4:44 pm
Sorry Daz,edited :wink:
dazleeds
old skool raver
old skool raver
munky30 wrote:yes there is :?
weird when i read that i couldnt see a link :rasta: not even had 1 yet so i guess that means its time for one :snigger:
Jimbob
Wed May 09, 2007 4:45 pm
Ah yea just forgot, the M50 manifold is cast, and the M52 one is mild steel so I think that means the cast manifold is TIG welded and the mild one MIG welded? Not up to speed with that sort of thing...
dazleeds
old skool raver
old skool raver
Wed May 09, 2007 4:46 pm
eko wrote:Sorry Daz,edited :wink:
phew thort id lost it then :mad:
still gonna have one anyway :rasta: :tongue:
munky30
100% Pure Council
:lol:
Rosc0PColtrane
Wed May 09, 2007 5:18 pm
:lol:
Like he needed a reason!!!
Don't encourage his wanton behaviour, Munky!!!
He didn't even offer to share!!
munky30
100% Pure Council
Wed May 09, 2007 5:24 pm
Thats because he knows I am a responsible citizen that doesnt partake in such debauchery.
Rosc0PColtrane
Wed May 09, 2007 5:30 pm
munky30 wrote:Thats because he knows I am a responsible citizen that doesnt partake in such debauchery.
I never said anything about accepting. It's just nice to be offered, once in a while!!
Andy335Touring
Thu May 10, 2007 7:07 pm
If i was doing a cheapish(?) E30 engine swap again the choice would be between the M30 and M52(more money though), does the M50 put enough power over a decent M20 to justify the cost/hassle ?
Ask your self if you will be satisfied with the level of power or will you get bored with it ?
Another comparison(power wise) would be tweaking the M20 with a cam/six branch/remap(or stroker) V's an M50 swap ?
munky30
100% Pure Council
Thu May 10, 2007 7:18 pm
Would you offer an ex-alcoholic a drink?
I would.... its funny to see them squirm.
diamondblacke28
Thu May 10, 2007 7:29 pm
andy335.
is the m50 quick enough keeps poping into the back of my mined.
the fact that i already have a good 525i i could use as a donour put the m50 down as a possiblity.
i do love that 3.5 m30 motor.
my 325i diamond black is already chipped and has an fse power boost valve and it doe's motor
also lowered,billys,cross drilled front discs sweet sounding exhaust(make :?: )
z3 selector,black leather
munky30
100% Pure Council
Thu May 10, 2007 7:33 pm
fse power boost valve? Whats one of them then?
Sounds remarkably similar to a certain useless resistor you can buy from egay....
jmc330i
Fri May 11, 2007 11:59 am
Hyperion wrote: The M50 is a new conversion and i believe is the furture for e30 engine conversions.
I think youre right there.
Not 100% sure but i believe that mocking up a manifold is a bit tricky and the electronics can be a issue, if you install the VANOS equipped engines.
Manifolds can be tricky and expensive, but can also be done as Eko said and not cost too much.
The wiring is done at the engine loom to body loom connector (C101) and is a case of rewiring the M50 loom into an E30 plug. The VANOS shouldnt be an issue as its all contained in the engine loom, but the EWS on the M52s does complicate things a little, although its not a major issue to wire in.
munky30 wrote:fse power boost valve? Whats one of them then?
Its basically an expensive fuel pressure regulator to replace the perfectly good one BMW used. Its meant to increase the fuel pressure faster than the standard one to give a richer mixture under acceleration. They have also caused the occasional under bonnet fire :eek:
James
'91 325i Sport
'93 318i touring 16v
diamondblacke28
Fri May 11, 2007 4:01 pm
ive had my emisions checked and it was lean.
i removed the fse and refitted the standard regulator.
and the reduction in responce and sheer acceleration was remarkable.
so i refitted the fse.
the improvement is unbelievable.
it does'nt half accelerate faster with an fse.
and its still doing about 27mpg
so dont knock it till you've tryed it
diamondblacke28
Fri May 11, 2007 4:03 pm
of topic or what lads.
i am after views on the m30/m50 engine conversions.
jmc330i
Sat May 12, 2007 6:38 pm
diamondblacke28 wrote:so dont knock it till you've tryed it
Not wanting to stray off topic too much more, but I have tried the fse, not on my E30 but on my Vauxhall (modded 2.0 16v) - lets just say my experience was different to yours :(
Of the 2 E30s Ive known to have the fse fitted, both caught fire as well as a couple of 16v Astras and Novas - I hang my head in shame for knowing such people :cry:
diamondblacke28 wrote:of topic or what lads.
Both conversions have little problems to overcome in terms of doing the work, but I dont think one is worse than the other. They are both well documented now on this and other sites, so help and info isnt going to be a problem.
Personally I would lean towards the M50/M52 for an everyday car, Im not sure I could or would want to afford the M30 running costs 8O
James
'91 325i Sport
Theo
Sat May 12, 2007 6:40 pm
Not convinced that the M30 mpg is so awful. From a tank I got 225 miles with regualr stints of driving like a twat, and alos 7/8 laps of Castle Combe. This is a 318is fuel tank so about 50ish litres?
Sat May 12, 2007 7:04 pm
55 litres i believe Theo
FSE's are wank, all hype, if it makes a difference there must be something wrong in the 1st place.. Or its a placebo
bigdek
Sat May 12, 2007 7:24 pm
Theo325 wrote:Not convinced that the M30 mpg is so awful. From a tank I got 225 miles with regualr stints of driving like a twat, and alos 7/8 laps of Castle Combe. This is a 318is fuel tank so about 50ish litres?
Thats only 18mpg(ish)
Not the end of the world but not too great .
Sat May 12, 2007 7:31 pm
but that inc lapping coombe and driving like you do when you get a nice new fast car.. so as an average that it good imo
Jon_Bmw
Dangerous when thinking
Sat May 12, 2007 7:57 pm
And a stint on the rollars...
DRIFTBOY
Sat May 12, 2007 8:03 pm
My 335 (M30) in every day driving - bit of town, bit of open road, bit of driving like I stole it, I get 19 - 21 mpg consistantly.
On a 200 mile run I got 27mpg.
I'm running with a 3.73:1 diff and 15" wheels, so it's not even a great motorway cruiser.
I was quite surprised and happy with these figures. (Assuming the milometer on my speedo is accurate that is!).
Martin.
Sat May 12, 2007 8:22 pm
Just experiencing an M30B35 for the first time myself, in an E34 535i (manual). It's got stonking torque from low revs, meaning that in normal driving you barely need touch the throttle so mpg isn't that bad (and mine has the dreaded FSE!), also revs to 6500rpm thanks to a Superchip :D
clubfx2
Sun May 13, 2007 3:27 pm
Any Zoner got info on a m50 conversion... I am keen to change my m20 engine for more bhp. Mountings, gearbox's, etc....
I had a semi worked m50 in my e36, was pushing 230bhp, luvly silky smooth and a 150mph motor.
Regards
Clyde
Go everywhere sideways...
clubfx2
Sun May 13, 2007 3:29 pm
I got 225 miles out of my 325i se. That was average 110-120 cruising speed...
Regards
Clyde
Andyboy
Alpina Colada
Sun May 13, 2007 4:26 pm
Hmmm. The M50 is a nice upgrade over an M20 - not solely for power but for economy and driveability. If I just wanted 20 bhp I'd be slipping a cam into the M20. But it's a pain to fit and the only readily available gearbox is the E30 318i M40 box - use the E34/E36 box and it's horribly undergeared until you fit a taller ratio diff (more money).
If you could find a mechanically good 535i or 735i manual that's what I'd be using - you can't argue with 1000cc extra and all that low down grunt.
jmc330i
Sun May 13, 2007 5:09 pm
Andyboy wrote:the only readily available gearbox is the E30 318i M40 box
Thats for the M50? Just out of interest, what flywheel and clutch combo is that using?
I read on here somewhere that the M50 clutch and flywheel can be used with the M40 box, but wasnt sure if thats right or if you get the same problem of the gearbox rotating like with the M20 box.
James
'91 325i Sport
