Hi Lads,
My cab has an M-Tech 2 kit on it but I'm not sure it has a cab one or whether it's just a standard mtech2 kit thats been modified.
The fit doesn't seem perfect, is there any way that i can tell for sure?
Cheers,
Stevo
Difference in M-Tech 2 Kits
maxfield
Look around the boot area for M-tech should be on the far right hand corner (drivers side)
I think the sills are deeper so the sides are different
mrLEE30
front and rear bumpers, boot spoiler and the door pods are all the same (assuming they are geniune) the only difference is the sill covers, the cab ones were wider to accomodate the wider sill (due to requirement for extra strength) if yours are not genuine cab ones you will see evidence of cutting underneath the sill plastic cover.
which bit is not fitting?
if its the bumper / valance then i wrote a tech article in the articles section on fitting and adjusting the bumpers and valance.
mrlee
mrlee
