flames from exhaust?
fuzzy
He who sleeps with "Gingers"
Sat May 05, 2007 6:06 pm
what causes this ? after a race today with my mate in his type r he says that flames were popping from my exhaust at high speeds after high boost when changing gear. is the cause of this something that needs attention sooner rather than later or is it something that doesnt matter. it does look cool from behind though he says winkeye
tylerma
Sat May 05, 2007 6:10 pm
I think its something you can expect from certain turbo applications mate
munky30
100% Pure Council
Own up, its you flamer kit really... you think its wikid koool innit.
lenny-d
Sat May 05, 2007 6:34 pm
munky30 wrote:Own up, its you flamer kit really... you think its wikid koool innit.
:rofl:
bigun wrote:sell my sport i'd rather f**k the dog :)
for sale one left kidney, high mileage, need slight bit of work, will p/x for front wings and rear qtr panels
Demlotcrew
Sat May 05, 2007 6:42 pm
Mines pops all the time 8)
Dont worry mate the only damage could be to the exhaust. (baffles)
But otherwise its very very cool!
Andrew
1an
Sat May 05, 2007 6:49 pm
you will normally get flames from the exhaust if you have more of a straight through pipe due to the combustion in the engine etc, but it definatly looks and sounds good.
nzracer
Sat May 05, 2007 6:52 pm
popping flames is uber :cool:
flamer kits are so :wan:
zaust
Zone day release
Sat May 05, 2007 6:58 pm
Hey m8.. Unburnt fuel hitting atmos at high speed. Dark orange flame, normal on cozzy lumps over 320 bh.
M30 Tech 1 Touring on gas.
zaust
Zone day release
Sat May 05, 2007 7:00 pm
I say find yourself a twin pleninth and run 8x grey's, some bd10 cam's 12 bar actuvator and a breather for the head.. :eek: winkeye
Onz
Sat May 05, 2007 7:45 pm
flames ROCK!!!
Turbo-Brown
Boost Junkie
Sat May 05, 2007 8:25 pm
Only reason you'd be getting popping and flames when you lift the throttle to change gear/decellerate is a mega lean light load mixture which passes through the engine and then ignites in the exhaust.
Probably nothing to worry about although it shouldn't really do it if the tuning's right.
CUTZ
Sat May 05, 2007 9:08 pm
dont really matter i had that on my honda civic vti its becoz of the exhaust :mad:
Jesus325iTouring
Frog freak !
Frog freak !
Sat May 05, 2007 9:11 pm
Used to look super cool on this twin piped Mark 1 RX7 Concept car I used to drive. :cool:
I was also lead to believe it's unburt fuel igniting in the exhaust.
snoops
Major Helmet
Sat May 05, 2007 9:31 pm
fuzzy wrote:what causes this ? after a race today with my mate in his type r he says that flames were popping from my exhaust at high speeds after high boost when changing gear. is the cause of this something that needs attention sooner rather than later or is it something that doesnt matter. it does look cool from behind though he says winkeye
who won? :)
Car-Nut
Sat May 05, 2007 9:33 pm
I heard it was the same as "JESUS"
My Evo 6 used to do it through a 4 " blitz exhaust when I was younger :D
Clive
Things are changing in the stable....
'88 Zinnobar Red E30 325i (Sold and missing it :O( )
http://www.carandclassic.co.uk/car/C50851
'02 Inidividual E39 M5(SOLD)
Turbo-Brown
Boost Junkie
Sat May 05, 2007 9:55 pm
It is unburned fuel catching fire in the exhaust, however the unburned fuel ends up in the exhaust as a result of a lean mixture on the over-run.
You can either get around the problem by having an over-run fuel cutoff (although anyone who's driven a 205GTi will tell you the cutoff's a deeply unpleasant thing to have to live with) or having a mixture that's not going too much over 18:1 on the light loads.
It's one of those things where you can have nothing and it's fine, or just the right amount and it's fine, but somewhere inbetween's a problem.
munky30
100% Pure Council
Sat May 05, 2007 10:19 pm
Whats it mean when a car pops and bangs but there's no flames?
When I let off the gas and let the engine brake, my car pops and bangs, afaik there's no flames and I know I dont have a turbo...
Jon_Bmw
Dangerous when thinking
Sat May 05, 2007 10:25 pm
Have you got an atmospheric dump valve?
Theo
Sat May 05, 2007 10:27 pm
Munky, does you bodgemobile have a badly blowing exhaust?
munky30
100% Pure Council
Sat May 05, 2007 10:28 pm
No, my bodge mobile has a 3" 'straight through HKS backbox on a standard front and middle section.
(It was free and got me through my mot before anyone starts)
Theo
Sat May 05, 2007 10:31 pm
A straight-through backbox? Surely that would simply be a pipe!
munky30
100% Pure Council
Sat May 05, 2007 10:34 pm
pretty much... you can see all the way through it but it does have some stuff around the outside... not much though.
Jesus325iTouring
Frog freak !
Frog freak !
Sat May 05, 2007 11:33 pm
Hmm,interesting,on my old 325 (I had when I was young and foolish) I put twin straight through Cherry Bomb silencers on,these were of the literal sence staight through,loud as f uck but no pop and banging on engine braking etc winkeye
Turbo-Brown
Boost Junkie
munky30 wrote:Whats it mean when a car pops and bangs but there's no flames?
It means it's running lean on the over-run. It makes no difference whether there's a turbo, supercharger or whatever, when the throttle's closed, you don't get boost whatever type of FI you run.
It's exactly the same for NA too, a lean mixture causes popping and / or flames when the throttle's shut and the revs are highish.
munky30
100% Pure Council
Sun May 06, 2007 12:01 am
Is it doing any damage?
I kinda like it... but if its not a good thing I'd rather do without it.
Turbo-Brown
Boost Junkie
Sun May 06, 2007 1:33 am
Probably not, there's not enough air passing through the engine for it to generate much heat.
Have seen someone's exploded silencer though, caused by a fuel buildup in the box which ignited with an almighty bang.
JazzMan
Sun May 06, 2007 8:32 am
Theo325 wrote:A straight-through backbox? Surely that would simply be a pipe!
This is what magnaflows straight through boxes look like on the inside:
http://www.magnaflow.com/wideopen/wideopen.asp
They are quite loud! But they do small ones and big ones so you can put complimentary smaller mufflers in somewhere in the system if it's too loud :)
glenbat
Sun May 06, 2007 11:43 am
Same as Zaust says Fuzzy, unburnt fuel being dumped into atmosphere (via exhaust) and igniting.. Higher powered cossies often do it with no source of ignition, and the last few yrs have seen every other turbo'd car have a flamer kit (a spark plug drilled into their exhaust and a switch on dash) fitted to look coooooooooooooooooool :cry:
My old saph used to do it quite a lot too (no flamer) usually on gear changes, I THINK as you back off the throttle a small amount of fuel is dumped and this tends to go up
CraigG
Sun May 06, 2007 12:56 pm
on vauxhall 16v engines, fuel is used to cool the piston crowns on over run, ie, it injects fuel with no spark, this then gets into the exhaust next cycle. afaik its fairly standard practice for turbo'd cars aswell, as the engine temps are much higher.
nothing to worry about tbh mate.
tailoutcharlie
Sun May 06, 2007 2:47 pm
both my mk2 golf gtis did that, assumed it was just something they all did.
used to think it made my car sound like a 'rally' car!
Chris
lenny-d
Sun May 06, 2007 2:50 pm
just get some anti lag launched on there and do it propperly
wwwwwwwaaaaaaaaaaaaammmmmmmmmmppp bang crack fart bang wwwwwwwwwwwaaaaaaaaaaaaaammmp
:D :cool:
nickso
Sun May 06, 2007 3:28 pm
apologies for the awful picture taken from a vid i cant get to work but this is my mates rsturbo which shoots 6 foot flames out the back, there is no flamer kit.
'88 e30 328i M52 track bint.
tailoutcharlie
Sun May 06, 2007 4:15 pm
jesus!
bet he doesn't have probs with people sitting on his bumper. :D
Chris
curryp
Formerly cuzz1510
Sun May 06, 2007 6:04 pm
that must be over fueling or somthing.thats unreal and must do some sort of damage 8O if not to the car,then to whoever is stood near! nice mobile bbq for this time of year though :P
Simon
Sun May 06, 2007 8:51 pm
My M3 does it too, and have witnessed it myself, when the missus was driving it!! 8O
