Yet Another 335I! ... Now With Turbo
Theo
Sun Apr 15, 2007 11:05 pm
Very nice and shiney! Wheels are very tasty.
DRIFTBOY
Sun Apr 15, 2007 11:09 pm
Thanks Theo!
It certainly looks a lot different from when you saw it a few weeks back! :D
How's your's coming along ?
Martin.
Sun Apr 15, 2007 11:10 pm
The Drift Hog looks way cool! Hmm, I have a spare strimmer engine kicking about...
DRIFTBOY
Sun Apr 15, 2007 11:15 pm
320iSE wrote:The Drift Hog looks way cool! Hmm, I have a spare strimmer engine kicking about...
It's a beast!
I calculated that if the engine could be de-restricted and rev to 9000 (not sure if it will but it is a two stroke ? ), with the racer bicycle gears on it it would do 74mph! :eek:
It's only reached about 10mph so far, the plastic wheels don't help, it just drifts and spins! And throws the chain off - which is under development!
It has potential! winkeye
Martin.
Theo
Sun Apr 15, 2007 11:20 pm
Mines getting there slowly, just need to have the exhaust modified a little so it will fit, then I can drive it - and evaluate the headgasket which I suspect to be a bit moody 8O Other than that, just needs front brakes and a few little niggles sorting - then it can come out to play :twisted:
DRIFTBOY
Sun Apr 15, 2007 11:33 pm
What makes you suspect the head gasket is moody ?
Apart from that, doesn't sound like too much to do though. ?
Martin.
Theo
Mon Apr 16, 2007 3:05 pm
I get a film of mayo under the oil filler cap, spots of mayo on the dipstick and a steamy exhaust. That said, I think I need to take the car for a good drive before jumping to any conclusions, it has onlybeen running on axle stands so far! I bought some K-seal today so will see if that helps, the radiator leaks anyway - so maybe it can fix two problems.
oze30
Mon Apr 16, 2007 3:15 pm
With regards to the drifthog-
You need to change the chain/sprockets for motorbike or something petrol driven. The teeth are man enough to cope with the power and rpm.
rfegards to the car:
Bloody heck. I want mine painted now! Sweet!
DRIFTBOY
Mon Apr 16, 2007 6:42 pm
Theo: Like you say, mayo can collect when the engine isn't driven with properly, I get it on my expansion cap doing lots of short runs but no other symptoms.
OZE30: Drifthog is in early stages of development! And it was made purely from stuff people had thrown away. It needs some rear axle bearings, different gearing and rubber tyres may help too! :mad:
And thanks! It was a whole load of work to prepare and paint the car, but worth the time and effort I think!
I just hope it doesn't get 'keyed-up' by some pikey chav ****er! :cry:
Martin.
Theo
Mon Apr 16, 2007 6:57 pm
That's reassuring to hear, I hope to be driving the car on wednesday once i have the correct m12 bolts for the propshaft coupling, so i'll report back with findings then. Sorry to go off topic on your thread!
DRIFTBOY
Mon Apr 16, 2007 7:04 pm
No worries mate,
You have pm!
Martin.
Mon Apr 16, 2007 8:45 pm
Hehe, I have a similar problem with my £200 E34 535i. Took it for an MOT last week and a rusted jubilee clip exiting the water pump gave way just as the tester was driving into the testing bay 8O Quickly legged it home (1.5 miles), running rough as sh*te (I think water got into the dizzy) and there was mayo on the dipstick :eek:
I'm hoping I haven't kippered the poor thing...(seems to start and run OK now that the clip has been replaced).
I also purchased a bottle of K-Seal just in case! Taking it for another MOT tomorrow, ho-hum...
Andy335Touring
Mon Apr 16, 2007 11:35 pm
Looking good mate :cool:
DRIFTBOY
Tue Apr 17, 2007 6:27 pm
Thanks Andy! :D
More trouble though! :(
Driving home from work, all is fine until I turn into my road. Had a bit of a shock, no power steering!
Had a look and -
Pas belt is gone, completely missing.
And the fan belt has turned inside out! :?
Even though it's full of fluid there is no resistance at all on the pas pump pulley, it spins very freely, not sure this should be the case so I assume my groaning, screeching pump has finally given up!
Aah well, spare fan belt on now, and some Weetabix for me before driving to work in the morning! :?
Martin.
nickso
Tue Apr 17, 2007 6:42 pm
8O :?
'88 e30 328i M52 track bint.
e30Alex
Tue Apr 17, 2007 9:27 pm
hey martin, they do spin freely with little resistasnce without the belt, they only resist when there is load on the steering rack, if that makes sence!Alex
Im a two car man. Shame my bike gets used more.Damn the MOT!
DRIFTBOY
Tue Apr 17, 2007 9:31 pm
That does make sense Alex.
I wasn't sure, thanks for letting me know.
A bit of a mystery to me at the moment as the belt had only been on for 5 months and 4000 miles or so, and I regularly checked the tension when I was doing other stuff.
The pump was very noisy though. :?
Martin.
e30Alex
Tue Apr 17, 2007 11:22 pm
hmmm,theres obviously somthing amiss!have a play with the pas pump pulley and check the bearings, they might be worn, but only showing it(and therefore throwing the belt) when the pump is hot.Alex
DRIFTBOY
Tue Apr 17, 2007 11:49 pm
Thanks dude, but I think I'll just get another pump and try that, it's an easy job to change it.
I might put my Z3 rack on then too! winkeye
Martin.
DRIFTBOY
Fri May 04, 2007 11:06 pm
UPDATE!!!
Got fed up with rattly, oil spewing, hot-running engine so I've decided to do something about it.
I got this -
I'm going to bung this one in pretty much as it is.
Apart from it came from an auto - going by the throttle position sensor and the fact that despite it having a flywheel bolted to it, no spigot bearing! 8O
Then I'll strip my original engine (again! :roll: ) , try and find out what it's problem is, turbo it and bung it back in.
Well, that's the plan! :?
Martin.
Toby_Unna
Boost Junkie
Sat May 05, 2007 12:29 am
DRIFTBOY wrote: turbo it
:twisted:
that's the nice thing about M30s, they're cheap and plentiful :D
top marks for doing something about it rather than putting up with it!
DRIFTBOY
Sat May 05, 2007 12:36 am
Thanks Toby!
Yeah they are cheap, I got that one with a manual gearbox for £150.
I know you can get whole cars for that money but I didn't want the extra time and work.
I'll be taking a lot of inspiration from you with the turbo conversion Toby, hope you don't mind! :o: :wink:
I'm not going for huge power and expense though. Going to try with mostly scrapyard and home made stuff to keep the cost down.
The most expensive bit will be the ecu.
Martin.
Toby_Unna
Boost Junkie
Sat May 05, 2007 12:45 am
that's a good price, manual box and fly are worth 100 easy - and you just try breaking one of these boxes! (i haven't managed yet lol)
hadn't driven mine for a month or so thanks to various issues with new wheels (for example 3 had 215/40 tyres and the fourth a 225/45; the bloke was driving around with it like that 8O )
anyway, got them sorted yesterday and went round the block, which turned into 40 miles and about £15 worth of entertainment. it's brilliant!
if I ever get down to Ant you can have a drive, that ought to convince you :D
and ECU wise - megasquirt all the way.
DRIFTBOY
Sat May 05, 2007 12:51 am
I was going to go the megasquirt route, I had a good chat with Ant about that when I picked up your old inlet manifold.
Would be great to see you and your car, hope I can make it when you are down here.
I'd love a drive, thanks!, but I don't need convincing!
I need more power - fact!
Martin.
Andy335Touring
Sat May 05, 2007 12:53 am
Amen ! :)
Toby_Unna
Boost Junkie
Sat May 05, 2007 12:56 am
well this is the first time in 8 years driving where I haven't felt the need for more power :D
(at the moment!)
is that engine just going straight in then?
DRIFTBOY
Sat May 05, 2007 1:02 am
Toby_Unna wrote: is that engine just going straight in then?
Apart from a spigot bearing - that I know of so far.
I'll probably swap over my new distributor cap and rotor arm, spark plugs and give it an oil and filter change, nothing major though.
Not sure when I'll get round to doing it yet, was going to do it this weekend but I've got a bad dose of tonsilitis so not feeling much like lifting 200kg lumps of iron around! :(
I'm keen to get my current engine torn down to investigate it though.
Martin.
Toby_Unna
Boost Junkie
Sat May 05, 2007 1:05 am
is the existing one still rattly when warm?
mine is a bit. nice and quiet when cold, tappety when warm. it's not getting any better or worse. sounds pretty nasty sometimes but i don't really care any more. :roll:
DRIFTBOY
Sat May 05, 2007 1:13 am
Toby_Unna wrote:is the existing one still rattly when warm?
Yeah, it's driving me mad!
And it's still got the cracked timing cover which is a mare of a job to do with the engine in and sump on.
And the power steering pump packed up so I've been running with no belt.
I thought it'd be easier to take it out and do it again! :roll:
Martin.
Andy335Touring
Sat May 05, 2007 1:16 am
damn shame one of us isn't closer to give you a hand
Jon_Bmw
Dangerous when thinking
Sat May 05, 2007 1:22 am
Are you going to change the sump gasket, for an hours work it will save you future grief for about £8 or so. Although if the engine you are rebuilding goes back in, it might not be worth it :mad:
This is commitment, respraying and new engine just for us Le mans lads :P You know all of our cars are turds right? :)
DRIFTBOY
Sat May 05, 2007 1:23 am
Andy335Touring wrote:damn shame one of us isn't closer to give you a hand
Very kind of you as usual Andy, but I should be able to get it done on my own, or there is usually an extra pair of willing hands not too far away from me.
I bought myself a hydraulic engine hoist last week as well so that should be easier than organising borrowing or hiring one.
Martin.
DRIFTBOY
Sat May 05, 2007 1:26 am
Jon_Bmw wrote:Are you going to change the sump gasket, for an hours work it will save you future grief for about £8 or so. Although if the engine you are rebuilding goes back in, it might not be worth it :mad:
I have thought about the sump gasket, be a good chance to take a peep at a few big end bearings, I might do as it will be a long time before the original engine is put back in.
Re LeMans: - New engine is not commitment so much as blind panic! 8O
Martin.
Andy335Touring
Sat May 05, 2007 1:27 am
Should be easy enough with two of you, i ended up working on my own the last time(dropped the engine out from under the car then hired a hoist to put it back in).
Toby_Unna
Boost Junkie
Sat May 05, 2007 1:32 am
yeah but think about all those bolts to undo :teehee:
my engine came out of the 535 via a Stihl saw, into the peugeot boot then into the e30 without being touched - and 15k later is still in there :cool:
i think 'lucky' sums it up best :o:
