3.5 into 325i
diamondblacke28
Post Sun Apr 29, 2007 10:35 am
im doing some homework and planning as ive always wanted to go down the 335i road.
my only consern is the wiring loom.
i no you use the 3.5 engine loom. cut the plug off get an new plug from stealers match up the wiring and away you go.
has anyone done this.
is there a diagram available to show what order the wires go in the plug.
snoops
Major Helmet
Post Sun Apr 29, 2007 3:17 pm
you might be better off posting in the engine swap section
ed325i
Post Sun Apr 29, 2007 4:07 pm
The 3.5 loom will plug in and the engine will run but there are a few wires that need swapping around to get every thing to work. There is no need to cut the plug off.
alan335i
Post Sun Apr 29, 2007 4:22 pm
i had to cut my plug off and swap it for the e34 one ,the e3o was a differesnt size,mine was a 91 e34 .
diamondblacke28
Post Sun Apr 29, 2007 5:30 pm
ed 325i did you use the e28 lump and loom. or e32,e34,e26
and what wires do you mean have to be swapped.
SPADGE
Post Sun Apr 29, 2007 11:08 pm
The earlier e34 had the correct sized plug to go straight into the e30 socket.
Its only the later ones usually with 'fly by wire' throttle's that will have the wrong plug.
SPADGE
Post Sun Apr 29, 2007 11:10 pm
diamondblacke28 wrote:ed 325i did you use the e28 lump and loom. or e32,e34,e26
There is loads of info in the thread below re wiring in the first few pages
http://www.e30zone.net/modules.php?name ... ic&t=38480
gareth
Post Tue May 01, 2007 12:34 am
the only other reason for plug cutting / swapping is if you have an early E30 with the square type plug. i've not owned one for years though so i can't remember what they look like!
my 1988 E32 735i loom just plugged into my 1990 325i one if that helps.
DRIFTBOY
Post Tue May 01, 2007 6:35 pm
I used a 1989 325i with a 1989 E34 535i manual donor.
The plugs matched and the engine ran.
The only wire mods I had to do was the green and black wire on the M30 loom (from pin 15 I think) put to the smallest spade terminal on the starter motor (or else the heater fan won't work and electric windows only open with the door open).
Also, on the E30 c101 plug, the black and white wire (pin 3) needed to be swapped for the black and purple wire (pin8) for the economy ( :? ) swingometer guage below the rev counter to work.
It's easiest to start with an E34 / E32 engine as E28 / E23 engines have a coolant pipe in the way at the back of the engine and the sump and oil pick up pipe will need to be changed to the later type to clear the E30 cross member.
Martin.
Theo
Post Tue May 01, 2007 6:39 pm
Also, on the E30 c101 plug, the black and white wire (pin 3) needed to be swapped for the black and purple wire (pin for the economy ( ) swingometer guage below the rev counter to work.
Interesting about pin 3 - my rev counter works, but not the swingometer gauge. Any ideas?
Sorry for the hijack!
DRIFTBOY
Post Tue May 01, 2007 6:45 pm
Yeah, swap pin 3 with pin 8.
I found it easier to pull the rubber boot right back, cut the wires, swap and solder them rather than remove the pins.
Martin.
Theo
Post Tue May 01, 2007 6:50 pm
Cool, that's another thing off the list then. Not sure if I wan't to know what the fuel consumption is though :eek:
diamondblacke28
Post Tue May 01, 2007 7:05 pm
what did you guys do for brakes on your 335's.
are the 2.5 brakes up for the job.
my 325i fronts are cross drilled
gareth
Post Tue May 01, 2007 8:16 pm
Theo325 wrote:Cool, that's another thing off the list then. Not sure if I wan't to know what the fuel consumption is though :eek:
that's why i'd like a M3 instrument cluster instead! no flappy-bad-economy-reminder gauge!
re brakes, i found the 325i ones (mine had mintex pads and ebc dics) too easy to cook. i'm running the 280mm WMS 4 pot kit now.
BristolBulldog
Post Tue May 08, 2007 1:49 pm
diamondblacke28 wrote:what did you guys do for brakes on your 335's.
I fitted 360mm hi spec monster 6's/ cost me 1400.
they won't fit inside 17's though.
