strut diameter
uberdrah
Mon Apr 30, 2007 4:37 pm
Hi,
I have a 1990 325i, would anyone be able to tell me the strut diameter, please?
Rich
rebelcruiser
Mon Apr 30, 2007 6:27 pm
i think yours would have the 51mm struts.
Mon Apr 30, 2007 10:43 pm
It did when it left the factory, but assume nothing after 17 years!
uberdrah
Tue May 01, 2007 12:21 pm
Which bit do i measure to check?
Templ8e30
Tue May 01, 2007 1:02 pm
Measure the tube diameter, anywhere between the spring platform at the top to the hub assembly at the bottom. It'll either be 51mm or 47mm (iirc).
Cheers,
Iain T
2007 Mazda 6 2.0 estate
etxp
Tue May 01, 2007 5:47 pm
should be 51mm
maxfield
Tue May 01, 2007 5:50 pm
51 or 45.
should be 51mm as all 325s came with these
