Hi , has anyone replaced the plastic rear window or the gas struts on the horseshoe cover on an e30 cab ? any idea what they are like to do ?
cheers paul.
cab questions !
Rear window ... you either have a zip-in or sew-in window. If you have the zip in you can buy a new window. Undo the stitching and unzip the old one ... but I have getting the new in and lined up is difficult. If you have a sewn in window then the roof will have to come off to replace it ... which means you may as well buy a new roof. Do a search on the site as there's a guy in Swansea who replaces the whole roof for about 250 quid.
Dampers are expensive to buy new .. go to a breakers yard and remove the dampers from an E30 front seat (2door or cab obviously) and use them instead. Changing them is just a matter of a couple of clips ... 5 mins tops.
G
G
I deserve 6 of the best ...
its easy just take your time lining the zip. if the 2 sides are out of line you will get crease lines across the window .....zip it up and if it looks ok put the clip in and glue around the edge to seal it
- grantfk10
- E30 Zone Meets/Events Team
Shinobi1 wrote:i would be interested to see them toolukescott wrote:Any chance of posting them here ? Or are they too long ?grantfk10 wrote:I have instructions for fitting a zip-in window if you need em?
Hi guys, it's a 3 page word.doc with pics. I can e-mail it.
