funny noise getting louder!!
LLcoolK
Tue Apr 24, 2007 12:23 pm
got a hissing noise comin from the rear and its got louder :( it starts as soon as you start it up. any ideas? cheers
Ziggy
Tue Apr 24, 2007 12:28 pm
Fuel pump on the way out...? Does it sound louder if you take the rear seat base up?
Tue Apr 24, 2007 3:28 pm
Never heard a fuel pump hiss! Probably an exhaust leak if it starts with the engine.
john325tewerin
Tue Apr 24, 2007 3:33 pm
Are you hearing it when you're inside and outside of the car?
LLcoolK
Tue Apr 24, 2007 5:03 pm
inside the car, its really getting on my nerves now!!
Ziggy
Tue Apr 24, 2007 5:06 pm
Brianmoooore wrote:Never heard a fuel pump hiss! Probably an exhaust leak if it starts with the engine.
Well no, but it's kindof a hissy whiney noise, no? I'm rubbish at describing noises anyway!
Tue Apr 24, 2007 6:58 pm
Hissy whiny noise sounds like the diff, but that won't start until you're moving.
Ziggy
Tue Apr 24, 2007 7:07 pm
Brianmoooore wrote:Hissy whiny noise sounds like the diff, but that won't start until you're moving.
True... I've had both, so my lack of skill at describing a noise is probably compounded by not actually remembering what a noisy fuel pump sounds like! :mad:
I'm fairly sure I know what the answer's gonna be, but do any of the snake-oil type things actually work on noisy (input shaft bearing I expect?) diffs? & can you use em with LSDs? :thumb:
Tue Apr 24, 2007 7:12 pm
Speaking of snakes, maybe you have a dehydrated Boa-Constrictor trapped under the back seat...
john325tewerin
Tue Apr 24, 2007 8:08 pm
Sounds like you need to tune your radio :wink:
