Hello everybody. I'm a newbie on this forum. I'm French and currently use a 325is turbo. My silent blocs need to be replaced.
What reinforced silent bloc could I fit? I heard about 635 silent bloc…
I would like to be sure before ordering from BMW.
I need the parts urgently (the order would be on Monday).
Thanks in advance for any advice!
What engine rubber mount for a 325i turbo?
frenchman
- Homo Hair
silent bloc? as in silencer or muffler for the exhaust system?
frenchman
Engine silentbloc, maybe bushes for you!
I mean the engine rubber mounts. this is better I guess!
- Homo Hair
ahhh.. sorry
not sure on that one, sure someone will post soon who is in the know
the 325i ones not strong enough then?
Jon_Bmw
- Dangerous when thinking
When I read it earlier, i skimmed it as short engine block.
frenchman
Sorry
Silentbloc=rubber mount in French!
frenchman
I found this on internet :
engine rubber mount from 5/6 trhu 82 3.0 3.3
Ref part number : 11 81 1 132 322
You do have to grind off 1 small alignment nub but otherwise they fit and work fine.
This seem to be harder than the OEM 325i ones.
Any feedback?
Any feedback?
e30_Turbo
- Boost Junkie
You could use the solid engine mounts I've seen on the PPF forum, it would be a harsh way of doing it but would and does work. I doubt any rubber bush will take that much abuse, maybe a poly bush is available, never looked myself.
I've sheared a set of stock engine bushes already although they were old, the stock new ones seem ok for now.
As always we demand some pics frenchman
toby
Interesting - says what it's meant to do.frenchman wrote:SorrySilentbloc=rubber mount in French!
