Oil leak (oil filter housing)
tomski
Thu Apr 19, 2007 8:44 pm
I have just had a good look at my 325 tourer and with the car running I can see oil dripping from the oil filter housing at the front. Does anyone know what I can do to fix this
Thanks, Andrew
UmarK
Thu Apr 19, 2007 8:53 pm
Hi, i had the same problem with my 325i convertible, my dad changed the oil filter relief valve but the leak remained, it turned out the leak was from the oil pressure switch so it might worth changing both of these. The valve is about six quid from the dealers and the switch is about 9 quid from GSF. I dont have the part numbers to hand, but can get them for you in a couple of days.
Thanks,
Umar.
tomski
Thu Apr 19, 2007 9:02 pm
Thanks for that mate, do you know where the oil switch is fitted. On mine I can see where the oil is coming from right in front of the oil filter there is a big bolt about 19mm I would say, and its dripping from there
Andrew
UmarK
Thu Apr 19, 2007 9:45 pm
Hi mate, i've asked my dad as he changed it for me, the oil pressure switch is by the oil filter housing its a 24mm bolt with a wire coming out of it. Not sure about the 19mm bolt. Hope this helps.
Umar.
tomski
Thu Apr 19, 2007 10:23 pm
Thanks, I will have a look in the morning
Andrew
Templ8e30
Thu Apr 19, 2007 11:18 pm
http://www.realoem.com/bmw/showparts.do ... g=11&fg=30
You'll probably need part number 5, a common leak comes from the valve assembly and BMW now supply the repair kit for it(number 7).
Cheers,
Iain T
2007 Mazda 6 2.0 estate
tomski
Fri Apr 20, 2007 9:51 am
Thanks for that mate, does look like the bit I need
Cheers, Andrew
