actuator..?
Right guys... im in need of a new actuator as the one essex turbo's replaced my old one with is very weak and i cant get it past 6psi... i want 10psi and was at one stage told a -31 actuator is what i needed..however, looking further, its been pointed out to me that -31 actuators open at 15psi !!! what do i need for mine then guys???
Turbo-Brown
- Boost Junkie
- Contact:
If you get yourself a boost control solenoid, you can keep the 6psi actuator and up the boost using the ECU.
Much more stable than an actuator alone and gives you the ability to map your boost
Sorry to hijack the post, but how does the boost control solenoid work, do you neeed to add anything else? I'm quite interested in doing this to my car as the ECU has the capability to map the boost. Cheers.
Kam
Kam
would love to do this but my m/s needs some bits added to make this happen, Ants been waiting on parts for ages and im not enjoying my boost, so im going the new actuator way ! just need to find the right 1..Turbo-Brown wrote:If you get yourself a boost control solenoid, you can keep the 6psi actuator and up the boost using the ECU.
Turbo-Brown
- Boost Junkie
- Contact:
The solenoid valve will have three ports. To install the solenoid you'd cut (and possibly extend) the signal pipe to the actuator.kam wrote:Sorry to hijack the post, but how does the boost control solenoid work, do you neeed to add anything else? I'm quite interested in doing this to my car as the ECU has the capability to map the boost. Cheers.
Kam
Then, you see which two ports on the valve are connected to eachother when there's no volts on the solenoid. You plug the gap in the signal pipe with the two connected ports and, if the solenoid wasn't turned on, you'd drive off as though it wasn't there seeing the same boost as you used to.
However, once you've wired up the solenoid so the ECU can control it, the ECU can start to up the boost.
The ECU will pulse the solenoid so that the boost signal to the actuator is interrupted which prevents the actuator from moving. When the solenoid it powered up, the third port on the valve (which vents to atmosphere) lets air that would be trapped in the actuator capsule out.
All good fun
Fair enough Erel, got the boost lust again then?
Ant
- Retired Team Member
- Contact:
I'm on the case for this, whats needed is a stronger actuator, no bleed valve can sort the surging issue Erel has
his W/gate is fully open @ 7 psi, so nothing will help short of an uprated unit.
-31 is no good, thats over a bar OPENING pressure, so would offer control in the 18-20 psi range , too high for the stock CR guys.
currntly has a -16 which is for 8psi or so so although weak, its working within its effective range.
trying to split the differance, but not so easy with hybrids due to the flow rates being outside the manufacturers specs.
watch this space.....
Email FTW
Watching mate!! ive taken off that brass joint thingy mijig, alot better with no spiking !!
, but i want to run at the maximum safest level, or should i say 9-10psi..... eagerly waiting on the m/s bits mate so we can map the boost... waiting your call soon hopefully.
SPADGE
Ant i have a few standard Cossie actuators laying around if you want to try them?
cliffybabe
- Powered by Nelly
Erel, U just like making me want a turbo more dont ya
When u took me out in ur cab i thought it was wicked and sods law it run well good whe we went for a spin
