started m50 swap(pics too)
eko
Old timer
Thu Apr 12, 2007 11:40 pm
So its only the engine side of the 101 you want?
Maybe a zoner with a breaker/scrap engine can sort you one out?
Worth a wanted ad winkeye
brian325i
Thu Apr 12, 2007 11:43 pm
ya the normal one that is on the car is there and perfect..the one thats on the engine loom went with engine..should have cut it off before i let it go ha ha
about the add..good idea..done 8) found a pic of what i want the finished product to look like . will post in few mins
Fri Apr 13, 2007 12:32 am
I think the C101 is about a fiver new.
When I said cam cover I meant the ally piece, not the plastic you did red and blue. IMO it would look nicer black 8)
brian325i
Fri Apr 13, 2007 12:42 am
oh right ..mmm might try it...might hide the scratches on it better too ha ha..
my friend works in main bmw dealer so ill find out
brian325i
Fri Apr 13, 2007 7:33 pm
priced prop and linkages from scrappy..he has em but its ┚¬100 :(
Took off inlet and wiring loom..im very afraid that my car will never work again..way too many sensors :(
but i gonna fit the new loom tomorrow and hope for best :D
jmc330i
Fri Apr 13, 2007 7:56 pm
Havent read through this thread yet, but the red/blue cam cover looks good 8)
Dont forget to block the inlet ports up if you leave the inlet plenum off, dont want any nasty bits falling into the cylinders 8O :?
James
'91 325i Sport
'93 318i touring 16v
brian325i
Fri Apr 13, 2007 7:58 pm
@jmc330i she's all covered in plastic, both rocker cover and inlet..and bonnet will be going on too for ggod measure..it will have purple in middle when i get round too it..priority is to re-wire the engine though :mad:
jmc330i
Sat Apr 14, 2007 7:34 pm
brian325i wrote:@jmc330i she's all covered in plastic, both rocker cover and inlet..and bonnet will be going on too for ggod measure..
Thats cool, Ive just seen some bad cases where a stray washer has fallen down an inlet port and nobody noticed, until they started the engine 8O :(
James
'91 325i Sport
brian325i
Sun Apr 15, 2007 12:14 am
better have a look just to be sure :eek:
jmc330i
Sun Apr 15, 2007 3:19 pm
When I say blocking the inlet ports, I mean like this....
James
'91 325i Sport
brian325i
Sun Apr 15, 2007 4:29 pm
@jmc330i..i hope nothin fell in as i just put a plastic cover over it!
*******QUESTION***********
I have 2 two pin female connectors left..which i presume one is the air temp sensor on underside of inlet and other is my spare water temp sensor which i had to wire direct..question is which one is the air temp..the brown and grey or the brown and brown/pink
any idea :D
brian325i
Sun Apr 22, 2007 3:06 pm
Yesterday i had spark and fuel after i earthed the relays
today put on coils and cranked it..nearly started but then nothing..now i have no spark and no fuel..
the relays are not being switched on..when i earth them it still doesnt work
any ideas??? :? :cry:
e30world
Sun Apr 22, 2007 8:21 pm
dnt ur get it right
brian325i
Sun Apr 22, 2007 8:29 pm
@e30 world...who what where and when :?
brian325i
Mon Apr 23, 2007 10:54 pm
project on hold until my exams are over..sad but has to be done :(
i will be back with a load of electrical questions in about 6 weeks haha
brian325i
Wed Jul 04, 2007 11:46 pm
what he said^^^ any ideas why my spark and fuel have dissappeared,also when(hoping i do) i get it running whats the best s/c kit for the m50,what power can they make without going at the internals?Custom eaton job or buy kit?Long time away yet prob but just curious,
The treehouse connector..how much is it?How do i bypass my bmw immobiliser?and would the auto loom im usin prevent my engine from working?
i just want to drive it now :-x :mad:
Thu Jul 05, 2007 8:48 am
As complicated as the C101 looks, only two wires (green and green/purple) actually have anything to do with the actual running of the engine.
The reason you engine doesn't run now will be simple, but you'll have to do some tests to find why.
12 volts at the reds on the DME relay? 12 volts at the green in the C101 with ignition on?
Test with a lamp, not a meter.
brian325i
Thu Jul 05, 2007 5:07 pm
really? i didnt think only 2 wires had to do with it,u just saved me a lot of time.dme relay..is that the name for the 3 relays???
thanks for your help :wink:
if there is no power at the relays when ignition is on is that normal,do they change on cranking or when you turn on the ignition
what should the crank position sensor read when cranking?any ideas ,if you know the answer of the top of your head you should write a book :D
Thu Jul 05, 2007 6:36 pm
CPS produces a pulse signal with a frequency corresponding to the rate at which the teeth on the wheel are passing it, with a 'drop out' once a rev when the missing tooth comes around. Amplitude of the pulses varies with revs, but isn't important.
DME relay is the main ECU one (usually white).
Check for power with the ignition switch at the green wire in the C101.
brian325i
Fri Jul 06, 2007 1:36 am
got wiring diagram today and went following from the source,i am pretty sure the ecu is broken,power going into it but not coming ouy,when i send power to it directly the relay clicks on and i get spark and fuel,so im gonna get an ecu tomorrow and see how that goes.number 1 is not giving power,56 has power and 2? cant remember,but the one which turns on the fuel and coils is not working,hopefully an ecu will sort that out,
Fri Jul 06, 2007 8:53 am
Highly unlikely (but not impossible) that the ECU is the problem.
brian325i
Fri Jul 06, 2007 5:42 pm
i hope your wrong lol
but if the power is going into ecu and not coming out the other side then surely its the ecu.what else would it be
i collected the ecu so i gonna throw it in tomorrow and see if i have power at the pin number 1,ie spark and fuel, fingers crossed,
brian325i
Sun Jul 08, 2007 2:48 pm
ecu was broke,
another thing to add to m50 development thread is that auto looms work too
brian325i
Mon Jul 09, 2007 1:10 am
one or 2 jobs to do before its on the road.
shorten 318is prop,
change output flange on g/box to an m42 one
put on gearlinkages
throttle cable,solder up wires and tidy them,
rad and plumbing
wire temperature switch
put in slave cylinder and bleed it,
mount ecu,
bleed all brakes,sort electric fan,
make my exhaust
it will never be done :(
hopefully she'll be 100% for santa pod in september 8) few of my friends are heading over for weekend,e30 convoy 8) all going well she'll be charged by then too
patrick85
Mon Jul 16, 2007 6:31 pm
Brian, just wondering whereabouts in Ireland you are. I'm a mechanic myself and thinking of doin the same conversion. If i could see one in the flesh it'd be great.
brian325i
Sun Aug 05, 2007 1:28 pm
hi patrick,im in cork,car isnt finished yet,holidays and all that prevented any work been done
here is my list of whats left to do
belts for ps and altinator
bleed clutch and put on new slave cylinder
sort electric fan,
make my exhaust and fit (manifolds done)
its running but idles very high,2000rpm,prob due to fact i had no air mass meter or lambda sensor
your welcome to look at it before making up your mind
brian325i
Mon Aug 13, 2007 12:48 am
took for spin today,with no exhaust :mad:
,need to fit exhaust and fan and im finished,will post pics of finished car sometime,thanks for the help.
Will be at the pod next month 8)
collecting 3.73 lsd on friday for her too winkeye
