89 325i touring in malachite..gonna get boosted..
brand new holset h1c turbo 18cm3 turbing house,
itg stainless manifold,
catcam custom grind with less overlap..
ford racing 440 cc injectors,i bought from usa,
volvo ic in top nick,
polished ic piping kit,
3 metre plus elbows silicon hose for ic,
40 mm external gate plus flanges to weld on,
megasquirt kit inc loom ,sensors etc
innovate lm1/ lc1 wideband controller,
metric blue headbolts
polished aluminium turbo oil filter
bailey dv26 dump valve,spare generic dump valve.
polished catch tank,
boost gauge
ive fabricated the exhaust pipe from turbo with 02 boss and vband fitted.
this is most of stuff,yes theres more...lol
i have recently offered this turbo stuff for sale...but i cant stand the questions/messers ,
so ive bought a 180k bottom end(cheers Ian)stripped it down and no wear to mention,but as its gonna get some smoke up its ass from the holset h1c...im gonna rebuild,new shells ,rings,seals,gaskets,oil pump+drv
ive cleaned,coated block in vht chevrolet red,modified sump to take the oil return-i did buy the landy td4 item but have gone for the bulkhead fitting option which is larger i.d...i also got some bukshee tubing and fabbed up the turbo return flange.got the stainless high temp hose with stainless super t clamps to match as shown....
so thats where im at,i will add in pics,specs as i do it..
oops nearly forget the cwp picture,i didnt realise the e36 m3 diff has same internals...e36 boys are buying the 3.91 diffs to swap in and of course their 3.15 s are up for grabs,so i got myself one....so another little job later on.
i must thank Ant,fozzymonster,turbobrown as there help and advice has been great...and they have been an inspiration from day 1...plus theyve gone through all this f.i build them selves so the advice is founded!!
[/img]
[/img]
[/img][/img]
[/img]
[/img]
[/img]
