m3 wishbone bushes
gareth
Post Thu Apr 14, 2005 10:07 pm
i'm going to fit my adjustable koni setup soon and was wondering about some m3 bushes while i'm at it.
does this make a worthwhile difference? where's a cheap place to get them? bmw only?
E30Adam
Post Thu Apr 14, 2005 10:18 pm
Definately do it, great improvement. Go for the eccentric M3 control arm bushes, they give a much more positive feeling through the steering.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
gareth
Post Thu Apr 14, 2005 10:34 pm
sold! are they a bmw only part?
E30Adam
Post Thu Apr 14, 2005 10:37 pm
gareth wrote:sold! are they a bmw only part?
I'm sure other places must do them but I got mine from the dealers.
Might be worth giving GSF a try but I have my doubts they'll stock them.
gareth
Post Thu Apr 14, 2005 10:46 pm
vauge price guestimate? :cool:
Andy335Touring
Post Thu Apr 14, 2005 10:54 pm
I think mine were 45(ish) from the dealers
Turbo-Brown
Boost Junkie
Post Thu Apr 14, 2005 11:59 pm
Anyone got a part number for these?
Sound like a good thing to do if the suspension's apart anyway :)
Andy335Touring
Post Fri Apr 15, 2005 12:05 am
Off set m3 bush's Pn: 31 12 9 061 222
gareth
Post Fri Apr 15, 2005 3:11 pm
are they an easy swap or am i gonna be into the usual cutting and bashing to swap them?
charlE30
Post Fri Apr 15, 2005 3:23 pm
Another alternative to the BMW ones are the Powerflex eccentric control arm bushes. Just fitted mine and you DO notice a difference in the way the car handles :cool:
BMW F31 335d xdrive
Turbo-Brown
Boost Junkie
Post Sat Apr 16, 2005 11:45 am
Bloody hell!
Just been onto my local dealers, they want Ԛ£85+VAT for EACH one of those!
That's insane money for a rubber bush!
Demlotcrew
Post Sat Apr 16, 2005 11:48 am
I really cant tell that much difference with these.
Andrew
charlE30
Post Sat Apr 16, 2005 12:08 pm
Maybe I notice the difference cause I don't have PAS??? or it could just be all the new bushes have made my car handle the way it did 184,000miles ago :lol:
Turbo are you talking about the BMW ones at Ԛ£85+VAT or powerflex?? The powerflex ones have an RRP of around Ԛ£18.95+VAT each... I know which I'd go for :thumb:
BMW F31 335d xdrive
Andy335Touring
Post Sat Apr 16, 2005 2:18 pm
The BMW bushs you only need to order one item as you get two bushs in the set.
85 + vat is to much money !
I'm sure i only paid 45 ish ?
Theres not a massive differance with these bushs but if you have to change them any way they are a step in the right direction .
Post Sat Apr 16, 2005 2:42 pm
Turbo-Brown wrote:Bloody hell!
Was that Barons in Ash Vale?
Turbo-Brown
Boost Junkie
Post Sat Apr 16, 2005 2:55 pm
Yeah, good ol' Barrons :)
The powerflex ones were about Ԛ£40 from Tweekies, but I'm beginning to wonder whether there's two in the set or one. I've ordered two anyway so I can always send one back.
gareth
Post Mon Apr 18, 2005 9:13 pm
Turbo-Brown wrote:I'm beginning to wonder whether there's two in the set or one. I've ordered two anyway so I can always send one back.
have they arrived yet? is it a car set? if it's 2 sets, pm me and i'll buy em off you!
Treeman612
Post Mon Apr 18, 2005 9:36 pm
I have just ordered from local BMW dealer - am paying Ԛ£77.01 inc vat for a pair (they only supply a pair, apparently.)
Also, Bentley manual says you MUST use special BMW lubricant when fitting new bush to control arm - apparently it sets after 30 minutes, locking bush to control arm. Is this BMW goo expensive, does anyone know, or could I use Loctite bearing fit, which I've got loads of??
E30Adam
Post Mon Apr 18, 2005 10:35 pm
Treeman612 wrote:I have just ordered from local BMW dealer - am paying Ԛ£77.01 inc vat for a pair (they only supply a pair, apparently.)
That's utter rubbish, fairy liquid does just the trick!
Demlotcrew
Post Tue Apr 19, 2005 11:23 am
I boil mine.
Andrew
Treeman612
Post Tue Apr 19, 2005 7:00 pm
Thanks, guys, I'm sure the fairy liquid (or boiling!!) will do the trick. I guess they must be a tight fit, so they do not need 'gluing' on, which seems to be the point of the BMW hard-setting lubricant.
Demlotcrew
Post Wed Apr 20, 2005 1:49 am
if you think about it, what purpose would the glue serve?
Andrew
Turbo-Brown
Boost Junkie
Post Wed Apr 20, 2005 8:21 am
To stop them rotating I guess.
Treeman612
Post Thu Apr 21, 2005 9:40 pm
I'm not sure, but I guess if the pin on the control arm is not a tight fit in the bush, it could move in and out, = floppy control arm? There must be a reason BMW recommend 'gluing' them in??
Post Thu Apr 21, 2005 11:29 pm
The inner metal sleeve of the bush is rubber lined, and must not rotate on the control arm pin, or it would wear rapidly.
You need a lubricant to get the bush on, but it must be of a type that is completely expelled from the joint after fitting., so no grease or the like.
I use a 33%/67% mix of washing up liquid/water, and pour hot water around the joint after fitting. Always get them on by hand, and haven'[t had one fail due to turning on the pin yet.
karlp
Post Fri Apr 22, 2005 12:56 pm
I have just fitted new powerflex bushes to my M3 and the design is different to the old eccentric bushes.
One thing to consider - as the suspension travels up and down the control arm 'rod' rotates, this if glued to the bush causes the bush to rotate or the rubber to be put under tension.
The new powerflex bush is made up of two sections and one rotates inside the other.
Karl
Post Fri Apr 22, 2005 7:00 pm
The rubber twisting under tension is what it's supposed to do with suspension movemevnt.
karlp
Post Fri Apr 22, 2005 7:27 pm
It may be what it is 'supposed' to do but it is a poor design. The really good ones use a spherical bearing that will freely rotate and consequently will last much longer.
Karl
gareth
Post Fri Apr 22, 2005 8:08 pm
actually, a spherical bearing will last nowhere near as long as a rubber bush in the real world. the benefit of a bush is, no friction on any parts. no lubrication required and no damage from shocks. spherical bearings require manitenance to keep clean and lubricated but rubber just gets on with it!
that said, some decent spherical bearings on all moving parts would give pinpoint precision on handling. :cool:
Andy325i
Post Fri Apr 22, 2005 8:32 pm
karlp wrote:I have just fitted new powerflex bushes to my M3 and the design is different to the old eccentric bushes.
Karl
How do you stop the Powerflex, ones turning?
karlp
Post Fri Apr 22, 2005 9:18 pm
The powerflex are of a two piece construction. The outer section is set rigid in the hanger and has the offset hole. The inner bush is set tightly on the wishbone and is unable to move. The inner bush is then placed into the outer bush and this will rotate slightly. As the inner bush has a locating section onto the wishbone it cannot move with relation to that.
As the suspension travels up and down slightly the inner bush moves against the outer but returns to its original postion when the suspension settles.
Karl
Andy325i
Post Sat Apr 23, 2005 12:37 am
cool! cheers mate, someone once said they were held in with a screw!!!! didn't think that would be the case
Regards
Andy
