Pollishing
Renton500
Wed Apr 04, 2007 7:52 am
Has anyone ever used one of those electric pollishing machines on their cars? Are they any good?
I'm contemplating buying one from aldi this thursday, it runs on mains and is only a tenner. It spins at 3000rpm apprently which sounds fast?
Just not sure if it's going to do more harm than good!
I normally use autoglym super-resin pollish and then extra gloss protection if that makes any difference.
325i Touring
marty1979
Wed Apr 04, 2007 8:11 am
Don't bother with any of those cheap polisher things. You want a polisher like this http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... mot_widget
I bought this exact one a while ago and it's a very good machine.
c76jon
Wed Apr 04, 2007 5:57 pm
a very very dangerous bit of kit without experience
be careful
m3ben05
Wed Apr 04, 2007 6:00 pm
Any thoughts on the one in the ebay link John?
I want a porter cable but not sure if i can justify the cost
c76jon
Wed Apr 04, 2007 6:05 pm
i was talking about the one in the ebay link!!!!!
porter cable.unless you have experience using a rotary or have something to gain experience on then porter all the way
itslike this
put a rotary on a panel and turn on
put loads of pressure on to rotary onto panel and it will just keep spinning on the spot
it WILL burn through the paint to metal
do the same with a porter and it will stop turning and far less heat generated as they spin off centre
only way you will cause damage with a porter is if you throw it at the panel!!
jon
m3ben05
Wed Apr 04, 2007 6:07 pm
Cheers Jon, looks like something else to add to the list then :roll:
Hows the CSL?
Renton500
Wed Apr 04, 2007 6:12 pm
Thanks guys, i'll leave it for the moment then and stick with the elbow grease :D
325i Touring
