Electric sunroof removal
Cava
Mon Apr 02, 2007 8:15 pm
I'm in the process of breaking my car down but can anyone tell me what parts to remove from an electric sunroof in order to provide the right kit for someone looking to convert a manual roof?
Thanks,
Cava.
Templ8e30
Mon Apr 02, 2007 9:52 pm
Wiring loom, motor, relay, switch, motor mounting plate and screws.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Chris-W
Mon Apr 02, 2007 9:59 pm
Not just motor mounting plate - remove the cable guide tubes as well.
I'd also include the front rigid headlining as well.
tomson
Mon Apr 02, 2007 10:11 pm
[quote="Chris-W"]Not just motor mounting plate - remove the cable guide tubes as well.quote]
Yes, this is the best way for sure but can be a PITA!
Chris-W
Mon Apr 02, 2007 10:20 pm
tomson wrote:Yes, this is the best way for sure but can be a PITA!
Damn sight easier than fitting a kit without them!
SPADGE
Mon Apr 02, 2007 10:29 pm
Its actually an easy job to remove the backing plate with the tubes attached just don't forget the 2 8/10mm bolts that secure the ends of the tubes under the headlining. Slide the cables out of the tubes and avoid letting them touch anything you want to keep as they should be covered in grease.
Cava
Mon Apr 02, 2007 11:01 pm
Cheers Guys for the details - looks like tomorrow evenings spare time is going to be used up!
Dave_M3
Thu Jun 12, 2008 11:48 pm
I need to do this tomoro morning...
I have all the headlining off and now just need to find out whats next. :?
Only have 2 hours or so to do it :roll:
