Rear Suspension Problems
My 325 touring's rear end didn't sit level when I bought it. The near side rear always sagged a bit (25mm ish) . After changing the rear springs I thought I'd cracked it. But I've just noticed that the near side rear has sagged again after less than 1000 miles. Probably about 10 -15mm.
Any ideas anyone?
Any ideas anyone?
handpaper
You routinely carry a very fat passenger?
Boot full of junk?
Speed bumps
Check your suspension bushes wear here causes many issues.
Check your springs again - rears are known to break near the pigtail.
Boot full of junk?
Speed bumps
e30bmlover
- Ac Schnitzer prophet
lol ''gash'' your user name reminds me of something???
stuartgallafant
Gash it's annoying isn't it? I had the same problem so changed springs (new), shocks (new), topmounts (new), subframe and trailing arms inc bushes (new) and it's still the same.
I'll be watching your thread with great interest and hope you manage to resolve the problem.
Charlie
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
Hi Charlie,
Thanks for you post. When I bought the car, the last owner just popped a spring (don't know whether it was new or not or even the right rating) on the off side as it was broken. I was just about to go off and buy a whole new set of shocks, bushes and springs but your post has worried me!
I think, I'll get underneath with a tape measure and verniers and see if I can see if theres a obvious source to the sagging problem. I noticed last night that the car tends to hang on one side on the handbrake which makes the problem look worse than it is. On a flat road it looks like more than 7-10mm which I suppose isn't that bad.
Could be something as silly as the top and bottom rubbers that the spring sits on?
- Brianmoooore
It could be absolutely anything, including a front suspension problem, or even a twisted shell from a past accident.
You need to check and measure absolutely everything, including getting it on a flatpack of some kind and measuring corner weights.
