Speedo readings with 17 alloys
madmerv
Quick question. Does speedo need re calibrated with bigger wheels than standard
code-
Different diamater wheels = speedo wrong
Or, more wrong then it allready is, most cars show too much.
Ziggy
Depends on the overall diameter - ie what size tyres you fit...
320Touring
try this link dude and dial the info in
standard on 15"BBs is 205/55/r15 all round iirc
http://www.miata.net/garage/tirecalc.html
it'll give you an idea of how far teh speedo will be out...
Zayyan
If the speedo is over-reading, with bigger wheels surely it'd be less wrong?code- wrote:Or, more wrong then it allready is, most cars show too much.
If you can, borrowing a sat nav (GPS) system is an easy way of telling for certain how far it's out, and then you can calibrate it - I think I remember someone typing up a thread explaining exactly how to do this a few months ago
madmerv
Been busy at work, thanks for the replies and the link. Will see how i get on. Cheers folks.
