are iS front calipers same as 325 ones??
ChizFab
Sun Mar 25, 2007 11:50 pm
basically wondering if a set of VW fit mims that will fit on a 320, but not a 325, will they fit my iS?!?!?!?
cheers
Now breaking.... e36/e34/e39 all models pm for parts!
E30Mark
Mon Mar 26, 2007 6:53 am
The 318iS has the same break set-up as the 325i.
Are you saying the wheels fit a 320, but not a 325i???? bit confused by your question.
PM for details
fowler
Boost Junkie
Mon Mar 26, 2007 6:57 am
caliper size may be an issue but are the wheels the right offset ????
EX A-Tech Workshop bitch !!!
gone but not forgotten
jaistanley
Mon Mar 26, 2007 12:26 pm
If they fit a 320 but not a 325, I assume they foul the 325 brakes? If so, they wont fit an Is. That said, the 320i and the 325i brakes are the same size, with just a tiny bit of extra width in the calipers and disks. Not enough to make a difference I'd have thought?
E30 wheel stick out on VW's so I assume you'll need (10mm I think??) spacers to fit properly but someone will be able to tell you exactly.
Jai
ChizFab
Tue Mar 27, 2007 9:26 am
cheers lads got wat i needed to know thanks
