my road rallycar
kevo
Post Tue Mar 20, 2007 12:08 am
how do all, here's a few pics of my ongoing project 318is.
current mods are...
1 ) bmw z3 steering rack, (after trying the e36 rack and finding it wasn't quite enough).
2 ) full polybush set
3 ) currently running alpina type shocks but will have full challenge spec bilsteins soon when finances allow
4 ) alloy top mounts (home made) on rear
5 ) rear strut brace
6 ) quickshift linkage and weighted gearknob/stick
7 ) weight reduction (27kg's of sound deadening ang speakers removed)
8 ) hydraulic handbrake fitted (home made again) and an extra set of calipers attached to rear arms.
9 ) 325i LSD rebuilt with ford clutch pack and a 4.45:1 cwp fitted.
10 ) quick release aluminium spare wheel post fitted (home made again).
11 ) Aluminium quick release spotlight brackets fitted (you guessed it home made)
12 ) tank guard fitted (home made) and modified original bmw sump guard fitted too.
13 ) interior lights upgraded for plotting
14 ) raised/stiffer springs all round currently budget bits an bobs jobbies although the back end feels great spring wise so that'll be staying when i convert the front end to coil overs (which will be home made of course).
15 ) stud and nut conversio
16 ) z3 diff bush (stiffer than stock)
17 ) modified sump (see pic) although this was replaced due to unnecesscary oil wastage occuring ha ha
18 ) modified and strengthened front subframe which the sump guard bolts to.
19 ) shiny look at me mud flaps fitted.
yet to do...
1 ) fit my front alloy top mounts (home made again)
2 ) make a smaller spring height adjustable coil over kit for front end
3 ) remove sunroof mechanism and seal up permanently
4 ) 18 point safety devices roll cage arriving shortly so will be fitting that.
5 ) battery cut off switch waiting to be fitted
6 ) navigators footrest needs fitting (home made too see pic)
7 ) i'm currently modifying a set of front headlights to take 'h4 bulbs too as it's neccescary for the new road raly rules if i'm to blank of the inner main beams.
8 ) i'm going to make an escort style world cup crossmember for the car and am looking to do something to the gearbox mounts too
9 ) i've currently got a freebee bucket seat and a good set of harnesses to go in so after my cage is fitted they'll be going in to an eventually being replaced by sparco evo seats when i can afford it.
thats all i can think of that i've done so far but i'll keep you posted on it as an when things get done. cheers
part 2
a couple of updates on the car the first is that i forgot to add 'fast road clutch' to the list above. the second is that i've started to install the cage. and when i say started i mean hardly anything. it's been hammering down all day and i'm working outside so thats an explanation to why so littles been done it's not cos i'm lazy ha ha!
heres a few pics of the cage firstly for those of you who haven't seen a safety devices 18 pointer (me up until last week ).
if you're wondering i'm the idiot in the drivers seat (well sort of drivers seat) and the navigator is my mate garth. you'll be pleased to know that the final results of that livingroom-carpetbagger rally we actually came runner up! only the settee beat us by the narrrowest of margins.
Anyway the first job was to remove the rear seats again and remove my rear strut brace which is now incidentally completely useless to me . waste eh? next i lined up the fancy brackets that came with the cage as best as i could and started cutting the hole which the cage will come through.
currently i'm still waiting on the rest of my cage parts to arrive so i'm only really plodding at the mo.
part 3
heres a couple of piccys of the car in action too.
part 4
i've finally had chance to start fitting the cage again today so here's whats been done...
firstly i cut out the pass side 'hole' for the cage mount to pass through and put some safe edge on it to make it look pretty and as i superglued it on it'll also seal the paint up to prevent rust.
next came the seat belt removal and door pillar trim ready for me to mess about with the main hoop.
the rest of the trim from above the dash also came out and i removed the headlining and folded it back so i could see the roof. the dashboard was then taken out which left a mass of nasty looking wires and cables which could cause rattles or at least look untidy so i set about clearing these up and also removing the sound deadening.
looks a lot better now and makes things easier to distinguish too!
part 5
another update for you, started to trial fit the cage today and found that i'd have to remove all the sunroof mechanism and parts after all not just part of it like i'd hoped for. so i spent nearly all day removing it and grinding the roof apart! to make things more difficult it hammered down most of the day although intermittently but i managed nonetheless i just got a bit wetter .
after removing the sunroof mechanism itself i found that there was alot more involved and here you can see the rest of the bits that needed removing.
it's difficult to see from this pic but theres the extra metal work that needed removing from inside the roof itself.
after carefully grinding the roof apart heres the extra sheet that comes with the sunroof. it weighs 4kg odd.
after removing the roof lining i then had to trim the rest of the lip out that was left as you can see in the photo, this was mostly glued on but was also welded on in some places by a tab which you can see in the photos. this had to be done very carefully as this was directly touching the outer roof skin and obviously i didn't want to damage it!
here you can see that the sunroof has been totally removed and trimmed and now looks a lot nicer and lighter!!
finally i got around to trial fitting the cage again but due to the weather really closing in i had to call it a day.
on the plus side after this work in the last two days i found that i've removed an extra 44kgs from the car (i've bought a little kitchen scales and been weighing everything i've taken out i've even kept a little list of everything (sad i know eh). the car is now sitting outside semi wrapped in industrial cling film (it's all i had to weatherproof it) .
part 6
how do again,
well heres another update for you, started the day straight off nights as it wasn't raining and i wanted to make the most of the weather by firstly getting the sunroof back in!
first job was to lighten the sunroof panel which was riduculously heavy to start with for such a relatively small piece of steel. i took off the outer seal and scraped off the sound proofing and then i saw that there were actually two layers to the skin so i set about grinding out the spot welds and scraping throught the glue. the result being that the sunroof now weighs alot less and looks the same from the outside. below is a picture of most of what was removed from the sunroof itself.
next I needed to put the skin back into the hole (ooerr that sounds rude ), to do this i bent up some of the ends of the lip that was hanging down as you can see from the pics and spot welded it together. i'm pleased with the result as it looks as though the sunroof is still completely normal from the outside as it sits well. The roof was then sealed up with a polyurethane black sealant (like tiger seal) and left to set.
next was to prep the floor ready for the feet to be welded into position .
after all the floor sections were prepped i slid the supplied floor plates under and set about fully assembling the whole cage together, the idea being that only once all the door bars etc were in could the final positions of the feet be properly established. after tacking the plates in including the multi point parts of the cage i.e. including those above the doors on the door pillars front and back etc. the cage was then disassembled and removed then proper welds put on. I found that the centre of the door pillars where on this cage is an extra bolting point had a very poorly shaped piece of steel supplied to weld in (cheaply does it :( ) so i fabricated a new 'Y' piece which you can see in the photo.
and that little lot believe it or not took me up until half past five! by which time i realised how hungry and tired i was and set about falling asleep on the couch. :D . i'll be doing a little more tomorrow and then that'll be it for a few days so i'll keep you posted. kev
btw now that the dash is out i've been offered to have it flocked for £60 so ive or take so i guess it'd be rude not to? and seems tha i've got to cut some holes in it shortly for the cage legs it'll look alot nicer with proper edges so i suppose i'll have to eh.
part 7
done a bit more today (booked half day from work to make the most of the dry weather :) . did a bit of painting to start with 2 layers of primer and 2 layers of paint from halfords which i may add is a pretty good match imo.
next i tidied up the roof where the sealant had spread and made a mess of the paint so a bit of time with some t-cut and a scalpel and it looks much better.
then i started to fit the headlining in but due to the fact that the roof is now 2 inches higher it wasn't straight forward, however with the aid of some spray glue and a bit of care it looks quite good. i also started to add trim back into the car as i have to keep it all due to road rally regs.
part 8
did a lot today but didn't actually get anything done if you know what i mean, basically now that the whole cage is attached in and ready to be finally assembled i needed to start on the triangulation of the front end. i started with the passenger side which firstly involved making a little space under where the glovebox would normally sit.
then i started attacking the other end where the fuse box sits as this is where the triangulation bolts to the car, at this point i'm not sure if the fusebox will be able to stay where it is or i'll have to reposition it elsewhere (i hope not :? )
as you can see under and surrounding the fusebox was also a load of sound deadening so this was also removed and put in the 'to be weighed pile'.
the next stage was make a small square hole in the two layers of the shell where the struts would pass through, this was easier said than done as it is very difficult to guage where the holes need to be but im pretty happy with the job so far.
after this was attached in place loosely i had to remove the outer wing to obtain access to the inner arch so that my second part could go through and again had to guess the hole position.
thats the progress today, i've still got to bolt it all together and then attach alot of the trim into the car before i can do the drivers side one it's all bit by bit stuff but it's coming slowly, i'm hoping to have a full weekend on it shortly but i may have other commitments yet i'll have to ait and see, i'm at the point now where i want it done as i want to go for a spin in it!!
part 9
finished off the left hand side triangulation today, i'm pretty pleased with it and once all the wiring was tidied up again it looks really neat.
here you can see the top section outside of the car, this was then sealed up with tiger seal, and the wing put back on.
i was quite pleased to find that the fusebox did fit back in it's original position, albeit not quite so snugly but still securely attached and the bonnet doesn't foul on it.
next job is to re-do the headlining with some spongebacked new stuff i bought (coming monday hopefully), the reason being mainly because it doesn't quite look good enough when the sunroof panel section of headlining goes back in, and it'll wind me up that i didn't finih it off properly.
part 10
spent a bit of time on her again today, first job this morning was putting that headlining in, blinking eck that was hard work! it came as a sheet of spongebacked nylon type cloth 3m x 2.5m and the instructions were - here is a can of spray glue.....
before...
after... (difficult to see i know but not as difficult as trying to get a good photo of a black roof looking at the sun ha ha!
whilst doing the headlining i also fished all the interior lights cable through small slits i made in the material for the next stage of work.
after this i reassembled the rest of the cage in the car for the final time on the drivers side and secured everything.
next came modifying the door pockets these were basically chopped up a bit and made to fit so that the door bars cleared them. the main reason for me keeping these was that they are very handy for the navigator.
before...
after...
next i concentrated on putting the rear seaats back into place (i need all interior trim remember for the regs), this involved a great deal of cuting and trimming of sponge which is a nuisance to cut might i add and seems to be better than iron at bluntening stanley knives :evil: but the finished job looks good and doesn't look like theres hardly any insides left :D by the way i took 4.5 kg's out of the insides of the seats.
i decided to make a start on the final piece of the cage too even though it was getting late, firstly the battery was taken out and the clutter removed. i then offered up the bars and having gained a little experience from last time made a smaller neater hole for the top part of the triangulation as you can see below. i then started to remove the wing but gave up as tiredness and darkness were coming after me with a big stick. i did discover quite happily though that the battery can remain in it's current location even with the extra bars in the way which is good news for me!!!
part 11
made a set of seat brackets in work today and modified a bit of plastic to make my bonnet release catch work again.
part 12
i finished off the cage today, woo hoo! but don't worry it's not quite done yet still got alot of bits left to do. i also had some asistance today off a mate; heres a little snippet of what was done...
pay particular attention in this photo to the set of safety flops you can see i say safety flops as a good combo betweeen boots and flip flops which are what all good garage mechanics are wearing this summer apparently.
and heres the fool in question, andjust in case you were wondering what he was doing down there he was fitting the plastic piece i made (with a few mods), not bad only took him two hours :?
still, i suppose we can't all be as handsome as me eh? ha ha
up till now i've removed 83kg's from the car in excess weight whilst keeping the whole of the interior for rally regs and it's going well.
i'll keep you posted on the rest of the project if anyones interested, just thought it may be handy for people to see pics.
Kevo
Dan318-is
Post Tue Mar 20, 2007 12:21 am
You are my absolute hero. :cool:
DRIFTBOY
Post Tue Mar 20, 2007 12:35 am
Fantastic work dude!
Car looks like a lot of fun! winkeye
Looking forward to the updates! :D
Jon_Bmw
Dangerous when thinking
Post Tue Mar 20, 2007 1:03 am
Wow, seriously cool.
And remind me if I ever want another track car, to buy one with a cage in it. That looks like a foul job!
Good effort lads.
J_Mac
Post Tue Mar 20, 2007 2:39 am
Nice work, wish i had the time to do something like that, you took a 13stone person out of that car already :cool: should help alot
maxfield
Post Tue Mar 20, 2007 3:26 pm
Top project!
northloop
Post Tue Mar 20, 2007 7:44 pm
That's a good read that is. I'm going through the same process at the moment. Well when I say I am, my mate is doing it for me :wink:
We have been encountering the exact same issues as you. Will the fuse box fit / wont it? What to do with the ECU etc etc. We decided to remove the heater giving us space to re-house any of the parts which need moving and fit a heated front screen.
A long process but it will be worth it in the end no doubt.
Keep the updates coming
DJ-325I
Post Tue Mar 20, 2007 8:19 pm
nothin like a gd bit of DIY, wht job do u do, u look quite a handy fabricator, top work, can't wait to see the final product and also how you get on with the diy coilovers as would like to do tht sort of thing on a track car when me and my dad get one!
m-dtech
Unapproved Trader caution
Post Tue Mar 20, 2007 11:05 pm
looking good mate, quick question though.............
whats the score on the legality of the rear seats ?
obviously the cage/door bars would obstruct a rear passengers exit of the vehicle........ MOT ?
alan1272
Post Tue Mar 20, 2007 11:06 pm
brilliant, loads of info, very helpfull! :D
gareth
Post Tue Mar 20, 2007 11:25 pm
that looks like a really fun toy you're building. that cage must weigh a bit though. that said, the still must be a load stiffer now so that must offset things a bit :D
datonyb
Post Wed Mar 21, 2007 12:58 am
absolute respect for what your doing mate
keep the effort and willing
well done
ex 325i came saw done the trackday!
then sold after 4hrs with a sign in the window
GOTTA LOVE THE BMW E30
kevo
Post Wed Mar 21, 2007 4:01 pm
hiya lads,
thanks for the comments back i wasn't sure if anyone would be interested in reading it obviously i was wrong :D as for the weight of the cage, i forgot to weigh it before i ut it in but you'd be surprised how light it is actually it certainly is no where near 13 stone! i'd estimate the whole thing to be around 30-40 kg's i may be able to find out one day but i certainly won't be taking it back out unless i have to ha ha.
as for the rear seats legality, as there are no seat belts in there no one is allowed in the back anyway and i only need seats in for the rally regs therefore come mot time i'll just take them out and mot it as a two seater, oh and the mot guy is fairly friendly as he rallies himself so it shouldn't be too much of a worry.
and my job is that i'm a mechanical fitter in a factory, but i also worked in the tool room for a number of years and also as a fabricator welder too all in the same factory, so now i tend to do a bit of it all, all the time keeps me in practice. yeah i'm going to start the coilovers as soon as the car is roadworthy again so i'd estimate that it'd be 4 weeks and the full suspension will be on. i've also got a few bits to do before i can tart the suspension anyway see.
i like the idea of the heated screen, how much are they anyway? although i'll probably keep the heater in mine instead as road rallying is always at night and is sometimes in the snow or any other weather so i think it's a wise choice really :eek:
kevo
jkarran
Post Wed Mar 21, 2007 5:12 pm
:cool: Nice project. My E30's a night rally car too, they're perfect for it really.
Anyway keep the photo's coming.
Here's a couple of mine showing my guard (lesson leared from crashing a mondeo through a hedge - big guards save rebuild time :D ) and one of it waiting for it's modified front legs. I've moved the cups up 35mm so I can keep the nice soft factory springs, comfy on the green lanes, ok on the road. I think I might have to modify it to stiffen the front arb though to keep the road handling.
Mine's a bit more ghetto than yours :chuckle:
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
Cotty
Hartge Crew
Post Wed Mar 21, 2007 9:05 pm
I love seeing things like this in progress rather than a few pic when its finished, you really get to see how much work is involved :eek:
kevo
Post Thu Mar 22, 2007 9:20 am
well the flocking dude got back to me nd said that it may be a couple of weeks, boo so i decided to have a go covering it myself. :? but instead of using the flocking stuff i thought i'd try it with the rest of my headlining material. sounds like a disaster doesn't it. don't worry i'm writing this with the benefit of hindsight though and i can jest about it knowing full well it turned out just fine :D here's a few bits and boogies.
it was all fixed together with some spray glue which is fabulous stuff except for when it gets on the pretty side of the fabric and all over your hands! but apart from that i'm pretty pleased with the job, plus it saved me money although i'm more bothered by the fact that it doesn't look like it's been done on the cheap it looks quality in the flesh. oh and by the way it's black it's just the camera making it look like a tellytubby shade.
Kevo
kevo
Post Thu Mar 22, 2007 9:47 pm
first job today after covering the dashboard was to fix the dodgy heater valve then refit the outer wing after re sealing the triangulation holes. after this i sarted work on the throttkle pedal, as you can see from the photo below the pedal was very close to the triangulation and i think i'd have been rubbing my feet on it all the time so i moved the pedals and also changed the floor mounted throttle to a more traditional setup, which i prefer for blipping down the gears with.
next was to fit some new carpet which was a buger of a job. i also couldn't seem to get a decent pic in the light so i'll get some more for you when it's all finished.
and finally the dash part fitted...
DRIFTBOY
Post Fri Mar 23, 2007 1:36 am
More great work dude! :cool:
I love that dash! Looks like it wasn't easy getting it to look so neat!
I've also wondered about the wafty floor hinged throttle pedal before, I might give that a go myself sometime! :D
Martin.
kevo
Post Fri Mar 23, 2007 10:48 pm
hi again, the beast is alive!!!!
took her for the first spin for ages today, wow! what a difference. i forgot just how much fun it is to drive and what a difference it is to what it was! the car seems much better handling, seems really stiff all round with no rattles and squeaks like i was expecting and i know i've done nothing to the power of it but it seems really quick too perhaps it's cos i haven't driven it for a while, having said that perhaps it's abit of weight saving and sound deadening removal too? whatever anyway really made me grin like an idiot and also pointed out loads of bits and bobs for me to do aswell.
still loads to do tho....
1 throttle pedal adjustment (it's too high)
2 clutch pedal needs moving to left an inch or so
3 refit seats when my new drivers seat arrives (took it out for a spin using the pass side one)
4 fit pass side harness
5 fix lights which for some reason didn't work (must have forgot to plug someting in)
6 fit all my lights for navigator
7 fit my to be made panel for front of dash which will incorporate the clock i've bought
8 fit my new strut brace
9 fit my new fuse box for spots potti etc
10 fit nav foot rest
11 get some roll cage padding and fit
12 underseal floor where i welded
13 tidy glovebox area
and a million other jobs that i wn't bore you with, and then i'll start on the suspension, in fact i may order it tomorrow ready to be built up soon :D an then after that i'll be making a start on the engine bay and engine side of things after i've done the lights mind blah blah blah.....
anyway whatever i do i'll post it but the main thing is now that i can go for a spin and have some fun whilst i'm doing it.
ta ta for now
kev
reggiegasket
Post Sun Apr 01, 2007 9:17 am
Kev,
I'm following your car with interest. Especially as I offered to buy it from you last year! Very impressive work there. Well done! :cool:
I have a standard iS which have done one 12-car rally in - came second and cracked the sump on a flat bit of grass... eeee!
I'm particularly interested to know about how to improve my car in terms of driving pleasure - would love to hear about how you are finding the Z3 rack, more about getting the LSD to the right gearing, and upgrading the suspension without lowering the car. Any tips greatfully received.
Cheers, G
kevo
Post Sun Apr 01, 2007 8:21 pm
hiya G, i remember chopsing to you, good to see you're doing events in it (which is more than i've done :? ). as for mods the z3 rack really genuinely is a must. you simply have to put one on, it'll shock you how much difference it makes it really is that good and a must for those tight hairpins and 90's. don't bother with the e36 rack i's not up to the job although it is a good improvement. that is the most worthwhile mod pound for pound in my opinion.then comes the all important diff, have you gaot an lsd in there yet? if so then great all you need to do is to get the gearing sorted which you can do a number of ways. what ratio do you have now? if you've got around a 3.9 then you could put an e36 318is gearbox in it which closens up the ratios and 5th gear is the same as 4th gear in your car now, i.e. it has a direct top 1:1. if none of that makes sense don't panic i can explain it in more detail if you like it's really not as technical as it sounds. alternatively you could go for a 5 series diff. now it's very important to get the right one though, you need a 520i auto from 1988-1991 model which has a 4.45:1 ratio in it (it'll confirm it on the diff tag), assuming you run 14inch wheels with 60 profile tyres this would give you a 117mph top end at 6500rpm. alternatively you could do what i may do and add both of them, this would drop the 6500rpm in 5th speed to 97mph which would make her very a frantic gearchanger. if you like give us a call and we can have a chops i'll pm you my no if you like btw have you got the ride height sorted yet as my suspension is being replaced in a week or so so mine will be going for sale.
drop us a pm.
Kev
kevo
Post Wed Apr 18, 2007 8:03 pm
how do all,
big long break between posts for me i know, i've been busy doing bits an bobs and haven't got too much to show for a couple of days work either but here it is anyway...
finished all the electrics (thanks by the way again to sunbmw :D ), and fitted my switches and fusebox plus potti plugs etc etc. also fitted my footrest and lighting inside the car. i've got a flexi light for the nav whilst i'm driving and a main fluorescent tube for plotting whilst stationary with a switch off the dash and also a set of led lights above the pass window for the handing over of time cards etc. this light is set off by a push to make switch in the navs footrest which you can see in the pic. i've also fitted a rally clock which is a timer and shows the time clearly in seconds too. this is switchable for when the car isn't in use. i've also fitted the seats i have the seat you've all seen before in the pass side and i've borrowed a sparco evo until my sparco sprint arrives (been having trouble getting a new one for some reason). the harnesses are all in and the throttle pedal was adjusted again to make it a little lower. I think thats most of it but i've still got a few jobs here and there in the interior to do.
i've also got my suspension now but am waiting for my springs which i ordered to arrive so in the meantime i'm going to make my world cup crossmember and engine mounts. i'll keep you posted as and when things happen.
Kevo
maxfield
Post Wed Apr 18, 2007 8:11 pm
Weeman
Post Thu Apr 19, 2007 8:33 am
Dude that is looking awesome, well done fella :D
Post Thu Apr 19, 2007 8:57 am
mate, what an uber cool project
very well documented
:cool: :cool: :cool:
tomze30
Post Thu Apr 19, 2007 9:17 am
I've just read this thread top to bottom..it's better than any book I've read recently. What a great amount of dedication and skill. Best of luck when you start competing.
kevo
Post Thu Apr 19, 2007 11:56 am
thanks for the feedback guys an the comments giving me a big head mind you tho.
kevo
kevo
Post Thu Apr 19, 2007 11:57 am
just a quick update, i changed the back arm and removed my second set of calipers from the rear couple of days ago, i've been plumbing in and stripping down the handbrake using the original car lines and tapping into them today (thanks again btw to gee for the fitting i thought i had but last minute realised i didn't typical.
i've also made a start on my world cup crossmember, i've made the crossmember part and am currently modifying the sump guard mount, and next week will be making a start on the engine mounts to go with it.
ric325i
Post Thu Apr 19, 2007 3:39 pm
oh my god that loks like fun!
this is a great project! pictures makes all the difference. i started reading this at work today thinking a 2 page thread wont take long to get through but it has taken all day! (i read in bits and bobs so i dont get seen on the web).
great work! a real intense strip down and a proper job all round! congratulations!
no the suck up is done.....hey if that rear strut brace is useless now why not donate it to a worthy project? :wink:
hehe
only joking i will get one soon.
fair play old boy
kevo
Post Thu Apr 19, 2007 6:31 pm
if anyone wants it, it's a home made one mind you? someone give me a tenner for it and i'll ask about postage costs?
ric325i
Post Fri Apr 20, 2007 1:22 pm
kevo wrote:if anyone wants it, it's a home made one mind you? someone give me a tenner for it and i'll ask about postage costs?
cool check the postage and if its not too much i will take it off your hands.
quick clean up / splash of paint
its a bit pikey and i like it for that reason :D
oldie323
Post Sat Apr 21, 2007 5:02 pm
hi there,nice job!!!!!!!!am thinkin of building an 24v 2.5 e30 for special stage rallying/track days.it'll replace my 205 gti.i just fancy sumthing right wheel drive!!!!am also building a 83 323 up to 2.7 spec,and running an e34 525 as a daily driver,where did u get the cage and how much?at least i wont have to put the insides back in,save some kg's.dash looks well pukka tho :D
kevo
Post Sun Apr 22, 2007 6:52 am
hiya, the cage came from phil at pdl (01246 240632), it wasn't cheap, but you can get various types and you don't need to buy all of the triangulation but if you do buy it all like this it'll cost around £900 delivered, i may have had a bit of discount so if you mention my name it may rub off on you too. projects sound a pleasure, i was toying with the idea of putting a lump in mine at some point but it'll be a while off probably due to cost etc, keep us posted on how things go.
Kev
rwd stands for right wheel drive i like it.
ric325i
Post Mon Apr 23, 2007 11:39 am
the right wheel drive thing was the reason i sold the 205 Mi16.
great motor but i had it for a while and wanted to see if i could drift?
the answer is losts of dents in my rear wheels. :cry:
but some great fun trying and i like to practice.
ric325i
Post Tue May 01, 2007 1:19 pm
yes i got the rear strut brace from Kevo!
well happy its not the lightest but the welding looks good and strong.
nice bit of work with the brackets :D
top bloke cheers man hope the build has not halted? have you been out in it yet??? :burn:
