Turbo Oil Feeds
Turbo-Brown
Boost Junkie
Post Tue Apr 19, 2005 9:12 pm
Greetings fellow turbo-nutters :)
So far the best idea I've come up with for an oil feed for my turbos is to drill a feed for them in the oil filter adaptor or make up a remote housing and do a similar thing, only further away from the block.
What's everyone else done?
I'm scared of starving a bearing or something! :cry:
Andy335Touring
Post Tue Apr 19, 2005 9:29 pm
i'm not to sure but some one said they had used some sort of T-peice that screewed into the block where the oil pressure sensor goes,if that makes any sense ? :?
Code: Select all
Oil feed------------------Oil sensor
                  Block
e30_Turbo
Boost Junkie
Post Wed Apr 20, 2005 10:19 am
Alex,
As andy said pretty much, we've got a T-piece made up to screw into the oil pressure switch and feed off that via a braided hose to the turbo. Ant has all the kit at his so I can't get you a piccie till 3rd May :cry:
I have a piccie of the oil return, but the feed won't go on till fitting day.
HTH,
Mark.
buster
Post Wed Apr 20, 2005 10:55 am
mine's going on the same,braided hose to turbo.
iKst
Post Wed Apr 20, 2005 11:22 am
What about oil pump ? Does the oil feeds to turbo affect oil pressure ?
Turbo-Brown
Boost Junkie
Post Wed Apr 20, 2005 1:34 pm
Hokey doke, the oil pressure switch is the thing that screws upwards into the block under the oil filter isn't it? :)
Thinking about it, unless there's absolutely no restriction to oil flow through the turbos, and the pump can't keep up, the oil pressure should still be taken care of by the pressure releif valve.
deano325t
Post Wed Apr 20, 2005 8:16 pm
this is what i did.
think its self explanatory
I ran a piece of brake pipe up for turbo .
soz for drawing .I can take a pic if u want
Dean
e30_Turbo
Boost Junkie
Post Mon Apr 25, 2005 7:09 pm
Sorry it's such a crappy pic, but it's PITA trying to get a good pic. It's mounted on the oil filter side, just a few inchs along towards the front end.
It's a landrover oil return pipe, an excellent idea, Cheers Ant :thumb:
Turbo-Brown
Boost Junkie
Post Mon Apr 25, 2005 9:23 pm
Oh forking excellent idea!
Don't suppose you've got a part number for those have you?
Do you reckon there's room for two of those on the sump?
Cheers!
Sjoerd320i
Post Mon Apr 25, 2005 9:44 pm
are we thinking the same thing why you would need 2 of them? :twisted: :twisted:
Turbo-Brown
Boost Junkie
Post Mon Apr 25, 2005 10:16 pm
Yes, yes we are :lol:
They're only little though, both from a Skyline GTR :)
Sjoerd320i
Post Tue Apr 26, 2005 12:11 pm
:lol:
that's wicked mate no turbo lag at all, gonna be flying everytime you just push the pedale :twisted:
Sjoerd320i
Post Tue Apr 26, 2005 12:34 pm
Andy335Touring wrote:i'm not to sure but some one said they had used some sort of T-peice that screewed into the block where the oil pressure sensor goes,if that makes any sense ? :?
Code: Select all
                  Block
this is a picture of someone who has such a T piece as you mean
have a look here this link is also in the general e30 chat under e28 turbo
e30_Turbo
Boost Junkie
Post Tue Apr 26, 2005 12:57 pm
Turbo-Brown wrote:Oh forking excellent idea!
Cheers!
Alex,
Ant sourced this for me, so I couldn't even tell you model of landrover it is from mate, he's back 3rd of may.
The actual pipe bit has been cut down quite a bit, I think it was about 6 inchs long before. Only thing I can think of is to send that pic to someone at landrover and ask if they can identify it, but I'll ask Ant when he's back for sure.
And I think there is plenty of room for more, some have fitted the returns to the front of the sump and that has a larger area to tap into. You have fins on the sides that mean you have only a few areas big enough to fit it. But 2 two would fit easy.
HTH,
Mark.
Turbo-Brown
Boost Junkie
Post Tue Apr 26, 2005 1:32 pm
That's brilliant, many thanks chaps :)
Jon_Bmw
Dangerous when thinking
Post Sun May 08, 2005 5:59 pm
What would be the result if you left the oil pressure switch out, do you get a warning lamp on the dash or are there more serious consequences of doing this. I'm currently trying to fabricate a t-piece out of gas and water connectors but its proving difficult.
As for the return, just an idea, and i'm waiting for someone to tell me NO, but what about retuning to the dipstick as i don't think that, that is under pressure?? And if you do it to the bottom of the dipstick bit its under the level of the turbo.
Sjoerd320i
Post Sun May 08, 2005 6:34 pm
wouldn't that be very dumb (no offence) to leave the oil presure sensor out? what if by some reson you lose your presure you can't see it and you turbo get ruined and probably also the rest of your engine :?
Jon_Bmw
Post Sun May 08, 2005 6:55 pm
329iturbo wrote:wouldn't that be very dumb (no offence) to leave the oil presure sensor out? what if by some reson you lose your presure you can't see it and you turbo get ruined and probably also the rest of your engine :?
No offence taken this would be a tempory measure only, not permanent. This would be to see if the whole thing worked before i start wasting hours on a t piece. So do you know if it will put the car in "limp hom mode" or simply do nothing apart from not tell me if the oil pressure is low??
Sjoerd320i
Post Sun May 08, 2005 7:05 pm
i don't know but i have never seen a car having problems when the oil presure is low (exept for a ruined engine but you get the point).
i think your ecu has nothing to do with the oil presure switch I think it's only connected to the light in your instrument cluster.
I'm sure somebody can tell more about it or correct me if i'm wrong
Turbo-Brown
Boost Junkie
Post Sun May 08, 2005 8:44 pm
Yeah think the oil light would be permanently on.
Wouldn't do it myself I must admit but then I'm a coward! :lol:
For my money, I'm fitting an oil pressure gauge just so I can keep an eye on things.
Jon_Bmw
Post Sun May 08, 2005 10:24 pm
Turbo-Brown wrote:Yeah think the oil light would be permanently on.
I wouldn't blame you for not trying it, what do you reckon to the oil return idea?? I might invest in an oil pressure guage at some point- i think it would be wise.
Are you going to have to split the oil feed in half for your turbos? If so does that mean two oil pressure sensors :? eeek. Ԛ£Ã”šÃ‚£Ãƒ”šÃ‚£Ãƒ”šÃ‚£ mounting up.
Turbo-Brown
Boost Junkie
Post Mon May 09, 2005 8:19 am
The dipstick's on the inlet side of the block isn't it (been ages since my engine was actually in the car :( )
Only problem I can see with that is getting enough fall on the return pipe as it's only gravity that pulls the oil back.
I will have to split the oil feed but I reckon that an arrangement similar to the block o' metal piccied above only with two tappings should do the trick. Should mean I can keep the one pressure switch and also provide a tapping for the oil pressure gauge :)
Jon_Bmw
Post Mon May 09, 2005 8:58 pm
Turbo-Brown wrote:The dipstick's on the inlet side of the block isn't it (been ages since my engine was actually in the car :( )
Yep fall is the right sort of word to describe that, as its almost a sideways motion more than a vertical motion. Perhaps i need to do some tests with a pipe, and pouring oil down it, seeing the difference in flow rates between the two. Thats something for the weekend i think.
Sjoerd320i
Post Wed May 11, 2005 4:46 pm
you mean something like this?
done a bit of photoshoping :wink:
