THE STEREOTYPICAL E30
ok, we have all had/currently have those annoying 'classic E30' problems...what are the most common?
Although now all fixed, I've had some of the most common with my E30 recently:
-Central locking issues
-Window catching on the roof when shutting door (cab)
-Rotted back box
-adjusted tappets
-Passenger window fell off its 'mounts'
-slight leak in boot
-electric roof issues
just waiting for the 'cracked dash' and im gonna shout BINGO!!!
WHAT OTHER COMMON PROBLEMS ARE THERE? - The Answers will help me plan for the future!
-Rotted back box
-adjusted tappets
- tommype30cab
brake light warning on the check control panel, a classic fault
"Racing is life. Anything that happens before or after is just waiting" Steve Mcqueen
rust on the inner rear arch.
clutch slave cylinder goes.
then the master goes a week later
um let me think........
im sure theres plenty more but its not that bad for 20 year old cars.
but mine is in the garage at present hence this list.
normally i would just be quoting the good stuff
Ziggy
F c u ked tca bushes, rear subframe bushes, rear topmounts. Not problems with the car as such - just a sign of age & cheapskate owners.
Cracked head with your 325i sir?
dimebag_from_hell
aye whats the craic with that? My battery went dead, stuck a new one in. Now it keeps telling me theres a prob with my brake lights.....
people say its an earth problemdimebag_from_hell wrote:brake light warning on the check control panel, a classic fault
just recently i think the 16 years has caught up with mine;
its been book in to the local specialist so much that when i renewed my insurance i genuinely answered to the guy on the phone:
'is it garaged at night'
'yes, sometimes my house garage, but most nights garaged down at BMG-Bmw''
and where is it parked during the day sir?:
''at work sometimes, but mostly down at the local Bmw specialsit''
here's what I've experienced with mine so far in nearly 2 years of ownership:
Reverse light switch fixed
Brake light switch (relay type thing directly above the brake pedal) fixed
Brake light on the control panel stays on even though they work! unresolved
ABS light comes on after driving more than 5mph! unresolved
Slight leak in boot and damp!
Engine mounts replaced
Central locking does not operate properly using the remote fob in the winter but works perfectly fine from spring onwards!
Fuel tank replaced!
I'll add some if I can remember the rest!
Fuel tank replaced!
munky30
- 100% Pure Council
ahh that reminds me.. my reverse lights dont work... but in the spirit of cheapness, you dont need reverse lights for mot so I havent bothered to find out why.
And my drivers door lock doesnt work. Central locking works fine from the passenger side (though sometimes doesnt lock one of the rear doors), but cant do anything from the drivers side lol. I like to think of walking from passenger side to drivers side every time I get in/out is akin to a bit of exercise so havent looked into why yet.
- PiperZero
- Contact:
Hello!
From my end, it'll be:
Rust....
Headlight switch (rotate like a safe dial to get correct dimness on instrument panel)
Central locking
Stuttering wipers
Intermittent boot light
Odometer gears (for both VDO and Motometer)
Water in boot (from leaky gasket around tail lights)
Temperature gauge
Row row row your boat shifter
Romantic low beam headlights....
Rust....
Central locking
Stuttering wipers
Temperature gauge
bigmattpowell
Hmm,
rusty fuel tank
perished fuel hose
front tca bushes
central locking
rusty arches
m40 death rattle
but for some strange reason I'd rather have "Bob" than a spanking new ford/vauxhall any day
rusty fuel tank
perished fuel hose
front tca bushes
central locking
rusty arches
m40 death rattle
12345kevin
More likely to be cheap bulbs, i'm sure it's been posted before. Or water in the rear lense as in my case !ric325i wrote:people say its an earth problemdimebag_from_hell wrote:brake light warning on the check control panel, a classic fault
From me
Fuel hose split - then split again, and again
Brake warning light on dash permanently on even though new pads and sensor fitted a couple of thousand miles ago
Leaky windscreen washer bottle
Damp in boot
Leaking heater matrix/valve
Rust - everwhere
split coolant pipes
Track rod ends
The list goes on and on
Damp in boot
Rust - everwhere
split coolant pipes
Track rod ends
bigmattpowell
Funny how on an e30 it always somehow seems worth fixing, but a small fraction of these problems on a 5 year old peugeot or renault and I'd be inclined to bin it.
Morat
AHHHH hahahHAHAHAHAHAHAHAHAhahahahahaaaaaaaPiperZero wrote:Hello!
perfect description, nice one
(psst, get some HID off ebay!)
Rosc0PColtrane
mine comes on when I indicate left sometimes!!!tommype30cab wrote:brake light warning on the check control panel, a classic fault
Anyone know a fix, drop me a pm please!!
Morat
From a touring perspective:
Leaky rear wash wipe hose (push button shower in the boot!)
Rusty tailgate
Rusty tailgate
Globulator
Check the earthing that services the rear clusters.blatantarrogance wrote:mine comes on when I indicate left sometimes!!!tommype30cab wrote:brake light warning on the check control panel, a classic fault
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
Globulator
My car has had it's far share of work done, although the last owner wasn't afraid to pay at the BMW dealer so lots was quite good anyway - i.e. newish alternator, fan coupling etc.
All jobs done by me except the front balljoint (was MOT failure).
All my changes are really down to age:
Cleaned up wiper motor plate to fix wipers
Cleaned out headlamps from leaks (new set due to go in too)
New indicator lenses and front fog lamps
New front bumper
New 15"BBS refurb + new Toyo T1S tyres
Stereo install w sub - took ages to do right
New electric aerial
Blu-tack in the steering column
New s/h under steering/wheel trim panel
Airbox heatshield + grill breathing
Bypass of throttle body heater
Switch to Mobil1 + new air+oil filters
Fuel filter to fuel rail pipe renewed
Tappets done + shiny domed s/s nuts + gasket
Service interval reset
Rear swing-arm brake-pipes to copper/nickel + flexies
New front dampers -> bilstein gas
Front RHS brakepipe (LONG!) to copper/nickel
New front brake hoses
Door trim correction (used to catch when opening!)
Steering fluid partial change
New blue temp sender
New coolant + thermostat + hoses
Instrument panel resolder to fix brake-lamp warning
New balljoint/arm
New distributor + rotor + plugs (as routine)
New gas-rams for boot and bonnet
Clutch master cylinder (slave was in history not so long ago!)
S/H oil cooler pipes
New Cambelt/roller/waterpump/coolant/sticker (120k -> 160k miles)
Oil of joints in hood mechanism
Next on the list is new back-plates + handbrake shoes + possible discs and pads. Not looking forward to the backplates. Also need new red bonnet and boot lid. I've probably missed stuff too.
Edited to add: It's a very easy car to work on, and well engineered so one wants to fix any bits that need doing - working previously on an MG Midget always made me cringe at what I saw.
New front bumper
New electric aerial
New balljoint/arm
- Brianmoooore
Specifically the earth pin in the plug and socket built into the back half of the clusterGlobulator wrote:Check the earthing that services the rear clusters.blatantarrogance wrote:mine comes on when I indicate left sometimes!!!tommype30cab wrote:brake light warning on the check control panel, a classic fault
- tommype30cab
ok ive thought of 2 more:
water in the headlights (oh how annoying)
and noisy injectors that dont make them selves apparent until after the tappets have been sorted!
i think its only fair that we start a thread on the good points of an e30 tho
- Brianmoooore
missing gasket for the sidelamp bulb holdertommype30cab wrote:ok ive thought of 2 more:
Early design of injector. A design quirk rather than a fault.and noisy injectors that dont make them selves apparent until after the tappets have been sorted!![]()
[img]http://
