E30 325i Sport Gearbox
Andy325i
How do I tell what box it is? It came from an early 325i sport but I can't see any markings on the case
Turbo-Brown
- Boost Junkie
If you bung it in first and rotate the output b one revolution whilst counting the number of times the input turns.
It should come out at 3.81 i.e. just under 4 turns. Think the non-sport 'box turns a significant amount more than this so it's a reasonably good method of checking.
No doubt someone will come up with an actual good wat though
Andy325i
cheers mate, will check that tommorrow. Anyone know if the Early/late Gearbox/diff ratio's the same on the sports?
I'm pretty sure they are same. Sport box had a different serial number to a normal box! but it eludes me! try the dealer they might help?
Andy325i
Lol the dealers normally need me to give them the part no, to get the right bits!Simon13 wrote: try the dealer they might help?
