318is - > 2.5 conversion
Conrad
Hi guys
I know this has probably been asked before, but a quick search hasn't found me the info I wanted.
The previous owner of my vehicle mentioned that it has the same struts etc as the 325i sport, is this true?
What parts would I have to replace to lump in a 325i engine and box in my 318is?
Very similar suspension/brakes etc. to a 325i, except that front springs on a 318iS are weaker for the lighter engine.
You'd need to change engine, box, radiator, engine loom and ECU, propshaft and diff, and a few welded brackets in the engine bay.
If the iS engine is OK, I wouldn't really recommend this conversion. The iS is slower than a 325, but not by much in the real world. What it lacks in grunt, it makes up for in handling.
Omi
- Witty custom rank.
And the boys would come round and kick your head in for murdering another iS.
...or is it?
Conrad
the iS engine is OK, but it lacks low down torque. Perhaps I'll be happier if I get a zone chip.
The problem as far as I can see, is theres very little you can actually do to tune an M42 without spending silly money, and that money would probably be better off spent on a 2.5i engine...
keggy
chip and big bore throttle body will help
stuartgallafant
yeah, im with omi on this...Omi wrote:And the boys would come round and kick your head in for murdering another iS.
conrad, kos spent less than £300 on engine mods for his iS, and it would keep up with 2.5's all day long
the M42 is a much better engine than the M20, and is lightyears ahead of it tech wise.
dont murder another iS, just to be on the desperate hunt for a little bit of low down torque. spend a good bit of cash on the iS and you'll be well happy
and as brian said, they handle a lot better than the 2.5's
Conrad
What you're saying does make sense, could you expand on what mod's Kos did to his? I'd quite happily spend £300 to keep up with 2.5's.stuartgallafant wrote:yeah, im with omi on this...Omi wrote:And the boys would come round and kick your head in for murdering another iS.
Cheers,
Con
m-dtech
- Unapproved Trader caution
if you do decide to do an engine conversion, stick in an s14
oldroydsr4
I believe lightening the flywheel makes a huge difference on the m42
stuartgallafant
jonb
Kos's car did not trouble 325i's.
I proved that on the way back from ace last year.
stuartgallafant
jonb
Yes you are.
Andyboy
- Alpina Colada
A 2.5 will always be 20 bhp ahead of a 318iS (136 bhp v 171) - so how will a 318iS 'keep up'?? Even if you dragged 150 bhp out of it, you're still way behind.
Not on your nelly.
Not on your nelly.
stuartgallafant
jonb
A chip, "zorst", and filter wont make hardly any difference.
Even so, my standard 325i 4 door which i was driving at the time, shat over kos.
The 318is is an ok car, good round the corners to, but it will never be a 325i on the straights.
Morat
Whats this we have here? another 4V6 thread?
Shurley shome mishtake?
Royalratch
This swap makes no sense at all.
The iS is more than just a modern twin-cam 4 pot E30. It's really balanced and the best package of all.
Get a chip, exhaust and K&N filter and maybe a diff change / flywheel change. Supercharge it.
Anything but a swap.
318iS would easily keep up with a 325i with very few mods.
