60mph=3000 revs?
1900sr
I've recently bought my first e30, a 318i Touring. One thing surprises me is that it seems to rev quite highly, in fact at 60 (65 indicated)it's doing 3000rpm. Is this normal, as the only cars I've had before that do those sort of revs are 4 speeders, or my Scirocco that had a close ratio box on it?
Gouki
not clued up on this but they have different ratio think it depends on the diff? You could put one in with different ratio although you slightly lose a bit of acceleration but get better MPG on long runs ie motorways.
1900sr
I'm not really bothered about changing things, but I was wondering if this was standard for this car, or whether it's maybe got a close ratio box as an option or as a later modification.
BadDave
On my 325 touring at 60mph indicated i'm pulling about 2600 rpm
Shows about 70 at 3000revs
Dunno the diff ratio(haven't checked)
m-dtech
- Unapproved Trader caution
might be worthwhile checking out what diff is on the back end.
if you want to loose acceleration and gain better mpg, fit a taller diff (lower ratio)
m
m
handpaper
1900sr - that sounds about right to me. BMWs are geared to rev out in top; it's not an overdrive gear, so at 6000 rpm you'll be doing an indicated 125-130 mph (actually about 115-120).
You have a 4.1:1 diff, standard on 318 and 320 saloons; BadDave's touring has the 3.91:1 that most tourings were sold with.
You can put a 3.91 on if you want to (I put one on my 320i), it's a bit more relaxed.
charlE30
Interesting thread this, got me thinking about my 325 tourer. At 60mph in 5th gear the revs sit at 3000rpm. It wasn't until reading this thread that I noticed the tourer at any given speed has higher rpm than my 325 saloon.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
airgunner
325 touring auto 60=2000 revs..BadDave wrote:On my 325 touring at 60mph indicated i'm pulling about 2600 rpm
StuBeeDoo
Your Touring will have been fitted with a 4.27 diff at the factory.1900sr wrote:I've recently bought my first e30, a 318i Touring. One thing surprises me is that it seems to rev quite highly, in fact at 60 (65 indicated)it's doing 3000rpm. Is this normal, as the only cars I've had before that do those sort of revs are 4 speeders, or my Scirocco that had a close ratio box on it?
Unless at some time in it's life it has been changed, the figures you quote sound about right.
Facelift E30's are low geared. Yours should be 16.64mph per 1000rpm in 4th and 20.54mph per 1000rpm in 5th.
HTH
Stuart.
BadDave
Looks like I'll have to check the ratio on my"spare slipper diff" then
It came from a pre facelift 325
StuBeeDoo
BadDave
Looks like it'll be going in the touring thenessbee wrote:Pre-facelift 325i diff should be a 3.64.BadDave wrote:Looks like I'll have to check the ratio on my"spare slipper diff" then
bmwe30mtech
Mine sits at exactly 3500 at 80, and about 3000 at 67-70, its a 318i also.
They do seem to rev high, anything over 100 and its screaming.
