318is starter motor removal
cheesebox
Post Wed Mar 07, 2007 2:18 pm
It looks unnecesarily complicated to get the starter motor out... Is it possible to do it without taking the inlet manifold off?
munky30
100% Pure Council
Post Fri Mar 09, 2007 10:51 am
with my new found knowledge of how to bolt together an e30 engine... I would say yes you can do it without taking off the inlet manifold. Its held on by two bolts on the bell housing.
cheesebox
Post Fri Mar 09, 2007 11:00 am
I had a look at my other iS which is "in bits" and there's some 10mm nuts on the end of those bolts you mentioned, at the bulkhead end. With a bit of luck I can undo those without the bolts turning. I can't grip the bolt head nearest to the engine though, it's too deeply buried under the inlet manifold. Let's hope those bolts are rusty and stay put!
b318isp
Post Fri Mar 09, 2007 1:47 pm
You need to run a lonnnnng socket extension through from the alternator under the manifold (I think you have to loosen the black plastic loom box under the inlet manifold). To hold the nuts on the bellhousing side, I used a large flat head scrwedriver.
