waterpump or thurmieetwat???
craigieeb
Post Mon Apr 18, 2005 3:35 pm
right i jumped in the car just before, set off to get some breakfast 3 mins down the road my temp needle went wooooosh off the scale, pulled over heaters blowing on full but nothing but cold air, poped the bonnet engine roasting hot, top water pipe solid as me in the morning :wink: the rest warm/cold ish, went to take off the cap and i could hear bubbling so i step'd back 3 paces let it settle and unscrewed the cap right off only to be met with a fcuking volcano erupting from the header tank :cry:
so what do you think it could be waterpump??? thermostat???
:cheers:
Davenotouring
Post Mon Apr 18, 2005 3:38 pm
Sounds like it could be the water pump, seeing as it warmed up SO quickly.
If the water isn't moving round the engine it will get hot very very quickly.
This could be the reason for the heaters blowing cold also...... :?
Might be the thermostat though :mad:
BMW 328i Cab - Daily Slag
Daryll
That's exactly what happened to mine, although I didn't notice the temp so carried on driving until the hose split. I changed the thermotwat and the water flump at the same time to be on the safe side. The thermostat was Ԛ£20 and the water pump was only Ԛ£13 so it was worth doing just incase.
@e30_daryll
craigieeb
Post Mon Apr 18, 2005 3:44 pm
nice 1 damnnn that was quick, i was just going to change both but if i can get away with it id just change one of them,
but i'll probably just do them both :roll:
JoeE30
Post Mon Apr 18, 2005 4:33 pm
this has happend to me the other day, i have changed thermotwat and water pump and still has made no difference.....Wont bleed and heaters blowin cold..................................................!
Thing is im a mech by trade and have never had such problems even with the good old reno's which are a biatch to bleed up.....
Joe
Andy335Touring
Post Mon Apr 18, 2005 4:56 pm
No hot air from the heater = Air lock
When you fill it try putting the ignition on and the heater on full hot to open the electrically operate heater valve.
craigieeb
Post Mon Apr 18, 2005 6:51 pm
right iv changed the thermostat,
put water in ran the heaters as i was doing it, temp stays cold so i took it for a spin and same again, 1 min down the road temp needle wooooosh again, and same again top hose rock solid and as hot as my lass, off with the cap, volcano,
so the water pump is now out and the new one is sitting in the kitchen waiting to go on in the morn
i dont see how it could of been an air-lock in the first place as its ran fine up untill today, iv had no pipes off or anything i use it every day aswell
