E36 318is gearbox (M42 engine variety)
E30318isbry
Post Thu Mar 08, 2007 1:04 pm
I bought an E36 318is M42 engine and box when my profile gasket went on my old 318is. The engine was swapped but my original box was ok so I put the E36 gearbox in the shed.
I now have a 316i E30 and I am thinking about putting an M50 engine into it.
Can I use the E36 318is gearbox?
Is it the same as the E30 318is gearbox?
TIA
stuartgallafant
Post Thu Mar 08, 2007 7:54 pm
that 'box wont fit onto an M50, unless you got a custom made bell housing. even then, i cant imagine it would cope with the torque
E30318isbry
Post Thu Mar 08, 2007 7:59 pm
For sale E36 318is gearbox 90k miles :D
stuartgallafant
Post Thu Mar 08, 2007 8:04 pm
:lol:
Andyboy
Alpina Colada
Post Thu Mar 08, 2007 9:20 pm
That box will fit an M52! The M40, M42, M50 and M52 boxes all have the same bellhousing bolt pattern and the E36 318iS box (Getrag D250 Series) uses the same gearbox housing as the 2 litre and 323i/523i. The ratios are slightly different but it's still the same 1:1 direct drive fifth gear.
It is a totally different unit to the E30 box though. The E30 used the old generation gearbox with an 0.81 overdrive fifth gear and these old boxes came in two sizes, 240 and 260, the number indicating the max torque loading the box is designed for. The E36 used the new generation gearbox with direct drive top gear and close ratios. Look on BMW ETK and you'll see that the garboxes are given names like S5D420G. This box is from a V8 530i. To decipher what that means is easy. S=Schalter (manual), 5=5 speed, D-Direkt (direct drive top). 420 is the torque capacity and G=Getrag.
Therefore an S5D250Z would be a ZF manual direct drive five speed with 250 torque capacity. Automatic gearboxes have the same coding.
So yes, a 318iS E36 box will bolt to your M52/M50 and work okay. 325i, 328i and 330i's used the next gearbox up, shared with the 3 litre M3. Because of the direct drive fifth, you will need a taller diff because it'll be like driving everywhere in fourth gear. So either fit a diff around 3.15-3.25, or use an E30 316i/318i M40 box and retain the overdrive fifth.
Kos
Post Thu Mar 08, 2007 9:32 pm
stuartgallafant wrote:that 'box wont fit onto an M50, unless you got a custom made bell housing. even then, i cant imagine it would cope with the torque
i was going to say what andyboys just said !!
look abouve stu
