Hi Chaps.
Any tips or tricks for getting valve springs out with having to pull the head off too.
I assume it can be done on a M20 2.5
Also, preferably without using compressed air (as I don't own a compressor).
I thought about stuffing the cylinder with rope or something like that.
And I guess I'll have to get a special kinda spring compressor.
All suggestions appreciated.
Also, while I'm at it. Any recommendations of which springs for a higher lift cam.
Thanks.
Removing valve springs without removing head
john325tewerin
wildeian
How? through the spark plug hole?I thought about stuffing the cylinder with rope or something like that
Could you not just set the cylinder to TDC?
john325tewerin
Aye, thru the spark plug hole and then set to TDC to push up under the valve. That was my thinking anyway but I've never done it before so I'm open to suggestions.
