325i turns over couple of times before it starts any ideas?
325ispart
my 325 some times takes couple of seconds to start maybe 5 or 6sec and other times it goes first turn. i changed the fuel pump changed the fuel filter the pump i put you can still hear it workin a bit i put the pump in another car and it works ok in it. i also changed the cold start sensorstill does it some times. any ideas??? thanks
My '88 325iSE did this also...but I sold it.
As an experiment, remove the fuel pump relay (orange one under cover by air filter) and link together pins 30 and 87 of its socket. Then try to start the car as normal. Any better?
Don't forget to remove the link afterwards, as it makes the fuel pump run continuously, even without the ignition on.
Purpose of all this is to see if the fuel rail is losing pressure when the car is stopped.
325ispart
went to check them relays there was one missing ther was only2 relays not 3. the one that was missing should have been one of the orange or yellow ones there was a green wire green and white a brown and there was a light green wire than went out and looped back into a pin for the same relay. would this missing effect the car starting some times? or is this ment to be a blank i have another 325 and had 3. thanks
march109
I had this problem, turned out the ICV lead had worked loose, pushing it back on helped.
and sometimes my car revs straight to 2000RPM when she starts, turned out to be my stupid feet pushing the mat upto the accelerator pedal! Sometimes it can e the simplest of problems.
Third relay is only used on cars with emissions equipment. Not relevant to your problem.
