i'm trying to get a short ratio lsd for my 85 320i but as 4.4 or 4.1 units seem hard to come by i thinking of building one.
am i right in thinking i can use the CWP out of a E34 520i(M20) in an e30 lsd to get the 4.4 ratio?
will it fit both large and small case diffs?(i don't have much experiance with bmw's so i'm unsure about the differences in these)
any help greatly appreciated.
diff building
alan1272
GermanGorilla
Hi,
alan1272- the E34 520i ''Auto'' has a 4.45 CW/P which will fit into
an E30 medium or Large case Diff.
I am not sure if the E34 520i ''Manual'' ran the same Ratio.
Regards,
The Gorilla.
Regards,
The Gorilla.
There are three sizes of BMW diffs caterogised by the crown wheel diameter,
168mm is the small case (most 4 pot E30's)
188mm is the medium case (mostly used on 6 pot E30's)
210mm is the large case (wont fit E30's without serious rear beam and drive shaft mods)
